Hello
I'm trying to send AT commands to the SIM908, bought off ebay,
SIM908 Board: http://www.ebay.com.au/itm/SIM908-Module-Development-Board-IPX-SMA-with-GPS-Antenna-for-Arduino-Raspberry-/171537455980
Using Leonardo Arduino board, also tried UNO board.
I just want to confirm whether the board is busted or the code/process is wrong.
The Leonardo code is
Serial1.begin(115200); -> Says in the manual(but changed it to check other baud rates)
while(!Serial1)
Serial.println("AT");
if (Serial1.available()) {
int inByte = Serial1.read();
Serial.write(inByte);
if (Serial.available()) {
int inByte = Serial.read();
Serial1.write(inByte);
And my process is:
- Connect wires
GPRStxd->RX(D00)
GPRSrxd->TX(D01)
GND-> GND
VCC -> 3.3V
2.Turn on Arduino then load code it.
3.Turn on SIM908 pressing power the other (2 L.E.Ds) turn on,1 blinking.
4. I try to send AT using different Baud rates, no response.
Also tried M2Msupport module tester no ports found/ no response.
Any help greatly appreciated.
