Arduino atmega328 giving random readings.
Hi!!
can anybody tell me why my arduino atmega328 is giving me random reading when I connect my pressure sensor to analog pin of arduino. If i connect that analog i/p pin to gnd then only it shows 0 reading. If i don’t applying any pressure then it should show 0 reading. why this is happening sometimes. sometimes it is showing correct values.pl. help.
Usually because you have connected it incorrectly.
What a surprise.
What pressure sensor is it? EXACTLY how is it wired?
rupaliambardekar: Hi!! can anybody tell me why my arduino atmega328 is giving me random reading when I connect my pressure sensor to analog pin of arduino. If i connect that analog i/p pin to gnd then only it shows 0 reading. If i don't applying any pressure then it should show 0 reading. why this is happening sometimes. sometimes it is showing correct values.pl. help.
How [u]exactly[/u] is it connected ? Are you using a breadboard ? Are the connections loose ? How long are the connecting wires ?
Have you commoned the grounds? Are cables shielded? Have you tried adding a 10nF capacitor between the anlog pin and ground to remove high frequency noise and interference?
Hi!! I am connecting analog pin with my opamp's output using connector which we can get ready made from the store. I hv not connected capacitor between gnd & analog pin. Is that really require? I' ll try it today.
Hi!!
4 Sensors are connected to multiplexer,multiplexer is connected to amplifier and amplifier’s output is connected to arduino’s analog input pin. I am not using breadboard. my ckt. is on pcb.
#define X_AXIS 1
// These constants won’t change. They’re used to give names
// to the pins used:
const int analogInPin = A1; // Analog input pin that the amplified o/p of sensor is attached to
int sensorValue = 0; // value read from the sensor
//int outputValue = 0; // value output to the PWM (analog out)
int CONTROLpin1 = 2; //*mux pin assignment to select channel no.
int CONTROLpin2 = 3; //*mux pin assignment to select channel no.
int CONTROLpin3 = 4; //mux pin assignment to select channel no.
int analogPin = 0; //
//int sensor = 0;
int i=3;
pinMode(CONTROLpin1, OUTPUT);//*
pinMode(CONTROLpin2, OUTPUT);//*
pinMode(CONTROLpin3, OUTPUT);//*
digitalWrite(CONTROLpin1, bitRead(i,0));//bit3*
digitalWrite(CONTROLpin2, bitRead(i,1));//bit2*
digitalWrite(CONTROLpin3, bitRead(i,2));//bit1*
// initialize serial communications at 9600 bps:
// read the analog in value:
sensorValue = analogRead(analogInPin);
// print out the value you read:
Serial.println(sensorValue); // print out the value you read:
delay(100); // delay in between reads for stability
Your code is using A1 which is the 2nd analog. Is your multiplexer physically connected to A1 or is it A0? Are you sure you want to do a bitRead()?
Simplify your circuit to 1 analog connected to the Analog i/p and see if it works.
I hv connected 10nF capacitor between analog pin & ground. Now I am getting random readings for sensor 0&2. sensor 1&3 are perfectly working.Also pl. tell me can we connect 3.3v to ARef pin directly or any resistor is needed to attach in between? I am supplying analog reference to ADC externally.Pl. reply.
