Good morning everyone,
I just bought a usb to serial converter to use with an arduino. However, I have not been able to use auto-reset with it. To reset the arduino, to my knowledge, I need to set the(RESET/DTR/Pin1) pin low.
I then followed this tutorial: http://www.instructables.com/id/Arduino-USB/step3/Decision-Time-Auto-Reset-or-not/ to make the auto-reset. It connects the DTR pin to a .1uf capacitor and then to pin 2 on the PL2303HX chip. Well, you might have guessed it, it doesn’t work! I tested the line from the PL2303HX and when a sketch is uploaded, it goes from 1.5v to 5v. The “output” by the capacitor stays at 0 volts which means it is broken?!?? Is there something I am missing?
The exact name of the converter is: USB To RS232 TTL PL2303HX Auto Converter
Thank you!
