Arduino Autonomous GPS Navigation
I am currently working on a robot that drives via GPS to a predefined place the robot is rather going wacko and I think the problem is in the code. Here is my code:
//pins
//only pwm and dir need to be connected.
int aPwm = 5;
int bPwm = 6;
int aDir = 7;
int bDir = 8;
//system vars
int low = 150;
int med = 200;
int high = 250;
int myHeading;
double destHeading;
float headThresh;
int a;
int b;
//compass
#include <Wire.h>
int HMC6352Address = 0x42;
// This is calculated in the setup() function
int slaveAddress;
int ledPin = 13;
boolean ledState = false;
byte headingData[2];
int i, headingValue;
//gps
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#define RXPin 2
#define TXPin 3
#define GPSBaud 9600
#define ConsoleBaud 9600
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// The TinyGPS++ object
TinyGPSPlus gps;
unsigned long lastUpdateTime = 0;
float dest[] = {
  42.35376, -82.57171};
#define destLat dest[0]
#define destLong dest[1]
{delay(30000);//wait for the gos to get a fix.
  pinMode(aPwm, OUTPUT);
  pinMode(bPwm, OUTPUT);
  pinMode(aDir, OUTPUT);
  pinMode(bDir, OUTPUT);
  digitalWrite(aDir, HIGH);
  digitalWrite(bDir, HIGH);
  //compass
  // Shift the device's documented slave address (0x42) 1 bit right
  // This compensates for how the TWI library only wants the
  // 7 most significant bits (with the high bit padded with 0)
  slaveAddress = HMC6352Address >> 1;   // This results in 0x21 as the address to pass to TWI
  pinMode(ledPin, OUTPUT);      // Set the LED pin as output
  Wire.begin();
  //gps
  ss.begin(GPSBaud);
  //compass
  // Send a "A" command to the HMC6352
  // This requests the current heading data
  Wire.beginTransmission(slaveAddress);
  Wire.write("A");              // The "Get Data" command
  Wire.endTransmission();
  delay(10);                   // The HMC6352 needs at least a 70us (microsecond) delay
  // after this command.  Using 10ms just makes it safe
  // Read the 2 heading bytes, MSB first
  // The resulting 16bit word is the compass heading in 10th's of a degree
  // For example: a heading of 1345 would be 134.5 degrees
  Wire.requestFrom(slaveAddress, 2);        // Request the 2 byte heading (MSB comes first)
  i = 0;
  while(Wire.available() && i < 2)
    headingData[i] = Wire.read();
    i++;
  headingValue = headingData[0]*256 + headingData[1];  // Put the MSB and LSB together
  myHeading = headingValue / 10;
  //Serial.print("Current heading: ");
  //Serial.print(int (headingValue / 10));     // The whole number part of the heading
  //gps
  // If any characters have arrived from the GPS,
  // send them to the TinyGPS++ object
  while (ss.available() > 0)
    gps.encode(ss.read());
  // Every 5 seconds, do an update.
  if (millis() - lastUpdateTime >= 1)
    lastUpdateTime = millis();
    // Establish our current status
    double distanceToDestination = TinyGPSPlus::distanceBetween(
    gps.location.lat(), gps.location.lng(),destLat, destLong);
    destHeading = TinyGPSPlus::courseTo(
    gps.location.lat(), gps.location.lng(), destLat, destLong);
    const char *directionToDestination = TinyGPSPlus::cardinal(destHeading);
    int courseChangeNeeded = (int)(360 + destHeading - gps.course.deg()) % 360;
  if(/*gps.location.isValid()*/true){
    // movement
    if(myHeading < destHeading + headThresh && myHeading > destHeading - headThresh){// Our heading is within 5 degrees of the target course
      a = med;
      b = med;
    if(myHeading > destHeading + headThresh){
      a = low;
      b = high;
    if(myHeading < destHeading - headThresh){
      a = high;
      b = low;
    applyVals(a, b);
  }else{a = 0; b = 0;Serial.println("FAIL");applyVals(a, b); delay(5000);
if (distanceToDestination <= 5.0)
      Serial.println("CONGRATULATIONS: You've arrived!");
      exit(1);
void applyVals(int A, int B){
  analogWrite(aPwm, A);
  analogWrite(bPwm, B);
  Serial.print("A");
  Serial.print(A);
  Serial.print("B");
  Serial.print(B);
  Serial.println("\n");
The code should drive the robot to the coordinates but the robot just turns in circles. I am using two motor controllers, a linksprite GPS shield and a parallax #29323 compass. All help is appreciated and I will gladly provide more details if needed!
Thanks,
L
The best way to debug problems like this is to sprinkle lots of print statements through the code, so that you can see at every step what values the program has, and what decisions it is making with them. Compare the printouts with your expectations. You don't actually need to have the motors engaged to do this.
This method is laborious, but it will eventually work.
Are you sure that the GPS is getting a lock ?
That may be far too long, or nowhere near long enough.
double destHeading;
float headThresh;
You realize that floats and doubles are the same ize, right?
  //gps
  ss.begin(GPSBaud);
You realize that there is nothing magical about the name, right? Make the instance name gps, so we know what the hell is attached to the software serial port. It won't hurt, I assure you.
If 70's good, 10,000 must me better, right?
Who cares if you haven't gotten a good sentence from the GPS?
See nasty comment above...
Bothyourspacekeyandyourcarriagereturnarebroken,andwe'retoassumethatyourGPSisflawless.Idon'tthinkso.
As your robot is not moving when you startup the gps can't give you a heading, and as a basic GPS fix is only good to 2 meters or so its not going to get any sane idea of your direction until you have move some 10's of meters.
No point in trying to debug the code as your concept is wrong. Try using a compass.
Mark
Ok , so I'm doing something wrong but I don't know what. So what code or what method should I use to drive a tank drive robot from its current location to a preset location??? I have tried looking at the webpage for one of the sparkfun avc cars, except that he doesn't explain very much of it. I basically need lots of pointers and code samples to get this project done. Another question, is the heading of the GPS relative to the gps's heading or relative to north??? All help is appreciated!
Thanks,
L
At what speed, over what distance? I have no problems using GPS data to get my trike from home to work, or to Provo, UT. But, then, the speeds and distances, and required accuracy, are compatible with GPS accuracy.
What have your observations told you?
luketheduke:
Are you getting a correct direction reading from the compass?
Are you getting a correct position reading from the GPS?
Until both of these work, you're wasting your time trying to get anything else working.
Peterh, both the compass and GPS are giving me the right location and heading data.
This robot will be going less than a kilometer to its destination waypoint so do I need to incorporate some math to account for the differences in true and magnetic north???
Thanks,
L
luketheduke:
That's a good start.
Is your sketch correctly calculating the range and bearing from its current position to the target position?
That depends on the magnetic declination at your location (which is small enough to neglect in a few places, but not in others), and whether you decide to navigate using true North or magnetic North.
according to a magnetic declination website I have a negative magnetic declination... I have worked out most of the errors in my software but now my compass(parallax #29323) is giving me weird measurements. It will say the heading is 0 then when I turn it, it will go up to ~110 and then start going back down rapidly.
All help is appreciated,
L
Have you calibrated your compass for gain and offset errors along each axis?
