arduino autopilot for raft
Hi arduino.cc. i have a big raft with a 6hp motor on it. i plan on using a windshild wiper motor to turn the motor right and left. i have no problem with the electrical side, but im having a lot of troble with the coding bit. i have found this code online, is it possipel to convert it to use with relays? code
Instead of servos? Seems unlikely. A servo motor can be moved in small amounts in either direction. A relay is either on or off.
What, exactly, do the relays control?
malthemail: i have found this code online, is it possipel to convert it to use with relays?
Yes. It's not a very good sketch but certainly parts of it will be useful for your problem. I'd start with an empty sketch and move over a little bit at a time. First put in just enough to read and display the compass. Then add a way to specify your desired heading. Then display the difference between your current heading and your desired heading. Then add code to move the steering motor.
malthemail: Hi arduino.cc. i have a big raft with a 6hp motor on it. i plan on using a windshild wiper motor to turn the motor right and left. i have no problem with the electrical side, but im having a lot of troble with the coding bit. i have found this code online, is it possipel to convert it to use with relays? code
