Arduino (AVR-GCC) für PIC (CCS-Compiler) - MLX90615 IR Sensor
Hallo,
Suche eine möglichkeit über mein PIC Board (PIC 18F4550) den IR Sensor von Melexis (MLX90615) über SMBUS auszulesen.
Habe hier einen Code für Arduino gefunden: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1214872633/13#13
Gibt es nun eine Möglichkeit diesen für C, ccs compiler, MPLAB, mit PIC 18F4550 umzuschreiben?
Hier mein Anfangsversuch, abgeleitet von dem Code siehe oben:
#include <i2cmaster.h>
#use I2C(slave,smbus, sda=PIN_C4,scl=PIN_C3)
#use rs232 (baud = 9600, xmit = pin_c6, rcv = pin_c7)
void main(
printf("Hello"); 						//printf
i2c_init(); 							//Initialise the i2c bus (i2c_start() ??? )
printf("Return from i2c_init");			//printf
int C4, C5;
C4 = input(Pin_C4);
C5 = input(Pin_C5);
output_c = (1<<C4)|(1<<C5);	//Inputpins: C4, C5, Shift 1 to left
while()
int dev = 0x5A<<1;  //0x5A = RAW IR Data on RAM
int data_low = 0;
int data_high = 0;
int pec = 0;
i2c_start_wait(dev+I2C_WRITE); //send start condition and write bit
i2c_write(0x07);   //Ox07 = To on RAM   //send command for device to action
i2c_rep_start(dev+I2C_READ); //i2c_rep_start(dev+I2C_READ); send repeated start condition, device will ack
data_low = i2c_readAck(); //Read 1 byte and then send ack
data_high = i2c_readAck(); //Read 1 byte and then send ack
pec = i2c_readNak(); //Read error check byte and send Nack to tell device no more data to send
i2c_stop(); //Release bus, end transaction
//This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
double tempFactor = 0.02; // 0.02 degrees per LSB
double tempData = 0x0000;
int frac;
// This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
tempData = (double)(((data_high & 0x007F) << 8) + data_low);
tempData = (tempData * tempFactor)-0.01;
tempData = tempData - 273.15;
printf((int)tempData); //Print temp in degrees C to serial
printf(".");
tempData=tempData-(int)tempData;
frac=tempData*100;
printf(""+frac);
delay(100);
Hier der i2cmaster.h code:
Problem eben, der AVR-GCC Compiler…
#ifndef _I2CMASTER_H
#define _I2CMASTER_H   1
* Title:    C include file for the I2C master interface
*           (i2cmaster.S or twimaster.c)
* Author:   Peter Fleury <pfleury@gmx.ch>  http://jump.to/fleury
* File:     $Id: i2cmaster.h,v 1.10 2005/03/06 22:39:57 Peter Exp $
* Software: AVR-GCC 3.4.3 / avr-libc 1.2.3
* Target:   any AVR device
* Usage:    see Doxygen manual
#ifdef DOXYGEN
 @defgroup pfleury_ic2master I2C Master library
 @code #include <i2cmaster.h> @endcode
 @brief I2C (TWI) Master Software Library
 Basic routines for communicating with I2C slave devices. This single master
 implementation is limited to one bus master on the I2C bus.
 This I2c library is implemented as a compact assembler software implementation of the I2C protocol
 which runs on any AVR (i2cmaster.S) and as a TWI hardware interface for all AVR with built-in TWI hardware (twimaster.c).
 Since the API for these two implementations is exactly the same, an application can be linked either against the
 software I2C implementation or the hardware I2C implementation.
 Use 4.7k pull-up resistor on the SDA and SCL pin.
 Adapt the SCL and SDA port and pin definitions and eventually the delay routine in the module
 i2cmaster.S to your target when using the software I2C implementation !
 Adjust the  CPU clock frequence F_CPU in twimaster.c or in the Makfile when using the TWI hardware implementaion.
 @note
    The module i2cmaster.S is based on the Atmel Application Note AVR300, corrected and adapted
    to GNU assembler and AVR-GCC C call interface.
    Replaced the incorrect quarter period delays found in AVR300 with
    half period delays.
 @author Peter Fleury pfleury@gmx.ch  http://jump.to/fleury
 @par API Usage Example
  The following code shows typical usage of this library, see example test_i2cmaster.c
 @code
 #define Dev24C02  0xA2      // device address of EEPROM 24C02, see datasheet
 int main(void)
     unsigned char ret;
     i2c_init();                             // initialize I2C library
     // write 0x75 to EEPROM address 5 (Byte Write)
     i2c_start_wait(Dev24C02+I2C_WRITE);     // set device address and write mode
     i2c_write(0x05);                        // write address = 5
     i2c_write(0x75);                        // write value 0x75 to EEPROM
     i2c_stop();                             // set stop conditon = release bus
     // read previously written value back from EEPROM address 5
     i2c_rep_start(Dev24C02+I2C_READ);       // set device address and read mode
     ret = i2c_readNak();                    // read one byte from EEPROM
     i2c_stop();
     for(;;);
 @endcode
#endif /* DOXYGEN */
#if (__GNUC__ * 100 + __GNUC_MINOR__) < 304
#error "This library requires AVR-GCC 3.4 or later, update to newer AVR-GCC compiler !"
#endif
#include <avr/io.h>
/** defines the data direction (reading from I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_READ    1
/** defines the data direction (writing to I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_WRITE   0
 @brief initialize the I2C master interace. Need to be called only once
 @param  void
 @return none
extern void i2c_init(void);
 @brief Terminates the data transfer and releases the I2C bus
 @param void
 @return none
extern void i2c_stop(void);
 @brief Issues a start condition and sends address and transfer direction
 @param    addr address and transfer direction of I2C device
 @retval   0   device accessible
 @retval   1   failed to access device
extern unsigned char i2c_start(unsigned char addr);
 @brief Issues a repeated start condition and sends address and transfer direction
extern unsigned char i2c_rep_start(unsigned char addr);
 If device is busy, use ack polling to wait until device ready
 @return   none
extern void i2c_start_wait(unsigned char addr);
 @brief Send one byte to I2C device
 @param    data  byte to be transfered
 @retval   0 write successful
 @retval   1 write failed
extern unsigned char i2c_write(unsigned char data);
 @brief    read one byte from the I2C device, request more data from device
 @return   byte read from I2C device
extern unsigned char i2c_readAck(void);
 @brief    read one byte from the I2C device, read is followed by a stop condition
extern unsigned char i2c_readNak(void);
 Implemented as a macro, which calls either i2c_readAck or i2c_readNak
 @param    ack 1 send ack, request more data from device
               0 send nak, read is followed by a stop condition
extern unsigned char i2c_read(unsigned char ack);
#define i2c_read(ack)  (ack) ? i2c_readAck() : i2c_readNak();
#endif
Funktioniert das so?
Solltest Du diese Frage nicht in einem PIC - Forum stellen? Grüße Uwe
Sollte ich? Okay...danke
