Arduino Avrdude Troubleshooting.
i found out recently that avrdude is having trouble communicating with my arduino mega and uno when using them as a ICSP/ISP Programmer. i dont know what happens but when i run avrdude in the command prompt i keep getting this error.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
(deleted)
Nothing, this is trying to burn bootloader to an external 16l8pu.
(deleted)
Avrdude is now picking up my arduino's but is still spitting out errors.
         Using Port                    : COM5
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
(deleted)
im not wiring anything, im trying to get avr dude to work correctly before i even think of doing anything, i uploaded the arduino as isp sketch to both my uno and mega and i get the errors on both
(deleted)
right! okay then, so now avrdude is working correctly, how do i go about uploading the bootloader to the 16l8pu?
Edit: I cant burn the bootloader because of this error! So im stuck again
(deleted)
This!
Atmel ATMEGA16L-8PU
something is not right at all now, i cant do anything while that error persists!
spycatcher2k:
I've never heard of a 16I8pu! so can't comment, but if you google it i'm sure the solution will present itself. :slight_smile:
Something is no right with AVRdude, i just attacthed my nano(which has been sitting for ages) and i still get the same error.
(deleted)
spycatcher2k:
No- somthing no right with your wiring, bus as you have not shown any, NO ONE CAN HELP!
Apologies for the last post...
just getting pretty annoyed that it just refuses to work.
heres the setup
(deleted)
spycatcher2k:
Then you will get errors!!
Twat!
i Apologise, i updated the last post.
if this helps, i have mightycore installed
Again, i apologise, avrdude now shows that its expected signature for ATmega 328p is 1E 95 0F
(deleted)
spycatcher2k:
You need to select ATMEGA16, then bootload.
finally! it burned the bootloader, i just tried to upload a sketch but came up with the syncing error again?
hmmm, bootloader is installed, but now having trouble with the sketch uploading, i used the arduino to breadboard tutorial, got nothing.
