Arduino based door lock
I’ve been trying to add RFID sensor to my door so I can unlock it with keychain. Everything worked good when I tried it on breadboard with arduino uno. But when I made pcb for it, then it stopped working. I tried “blink” sample on the pin where relay is and it worked perfectly, but when I try to trigger that pin with sensor it does nothing. Then I moved the atmega back to arduino board and it worked again, so I think the problem is with communication between atmega and RFID.
Here is code sample. I just used piece of sample code in library for RFID and changed it a little so there should be no problems.
I attached picture of wiring I used to make pcb board in case the problem is in there.
(1* I used 3 diodes in series to get 3.3 out of 5V and sensor powerd up, and I checked, there is 3.1V on it)
(2* The connector that is pointed with this arrow is for RFID sonsor and it is wired correctly, same way I wired it when I was testing it on arduino board and breadboard)
I did not tried this scheme on breadboard, It is not the same because I used arduino board to test it so I don’t know where the problem is
/*pinout
SDA     -> 10
SCK     -> 13
MOSI    -> 11
MISO    -> 12
IRQ     -> not connected
GND     -> GND
RST     -> 9
3,3V    -> 3,3V
#include <SPI.h>
#include <MFRC522.h>
byte readCard[4];
constexpr uint8_t RST_PIN = 9;
constexpr uint8_t SS_PIN = 10;
MFRC522 mfrc522(SS_PIN, RST_PIN);
int master[4]={0x8B,0xD2,0x71,0x5B};
int br=0;
int br_kor=6;
String korisnik[6]={"Bane","Veljko","Milan","Sloba","Kiki","Nenad"};
int otvori=0;
int korisnici[6][4]
    {0x8B,0xD2,0x71,0x5B},
    {0x10,0x51,0x3C,0x52},
    {0x9E,0xF3,0x0C,0x85},
    {0x96,0x38,0x10,0x85},
    {0x70,0x38,0xE9,0x87},
    {0x10,0x56,0x6E,0x3B},
int compareID(int b, int card[6][4]);
  delay(5000);
    pinMode(5, OUTPUT);
    digitalWrite(5,0);
    //Serial.begin(9600);
    SPI.begin();
    mfrc522.PCD_Init();
    uint8_t getID();
      getID();
      for (br = 0; br < br_kor; br++)
          if(compareID(br,korisnici) == 4)
              Serial.println(br);
              Serial.println(korisnik[br]);
              otvori=1;
      if (otvori == 1)
        digitalWrite(5, HIGH);
        delay(5000);
        digitalWrite(5, LOW);
        otvori=0;
uint8_t getID()
    if (!mfrc522.PICC_IsNewCardPresent())
        return 0;
    if (!mfrc522.PICC_ReadCardSerial())
        return 0;
    Serial.println(F("Scanned PICC's UID:"));
    for ( uint8_t i = 0; i < 4; i++)
        readCard[i] = mfrc522.uid.uidByte[i];
        Serial.println(readCard[i],HEX);
    Serial.println("");
    mfrc522.PICC_HaltA();
    return 1;
    int m=0;
    for ( uint8_t i = 0; i<4; i++)
        if(card[b][i]==readCard[i])
            m++;
        if(b==5)
            readCard[i]=0;
    return m;
Thank you in advance for your time and help!
