So, let me introduce the project I've been working on last summer:
MegaDrivePlusPlus - A modchip for the Sega Mega Drive (AKA Sega Genesis)
It's basically an evolution of the well known (well, in the retrogaming community at least...) D4s/Seb mod, taking inspiration from the SuperCIC+IGR mod available for the SuperNES.
It has the following features:
EUR/USA/JAP mode switching: this effectively makes your console universal, allowing it to bypass region checks and to run all games without resorting to an adapter.
If you come from a PAL region, you will also be able to run most games at 60 Hz, which means full-speed and full-screen! Get rid of those black bars! See the difference here: Sonic 1 - 60Hz - 50Hz comparison - YouTube!
The mod is switchless, so you don't need to modify the aesthetics of your console installing ugly switches, but rather you will be able to change the region:
Through the Reset button: Keep pushed to cycle through modes.
From the Player 1 controller pad: Press Start + B + Up/Down to cycle through modes or Start + Down/Left/Right to set your desired mode (according to the actual chip you have installed, more on this below).
The last used mode is saved automatically after 5 seconds and reused at power up.
Supports a single led, common-anode or common-cathode dual or RGB LEDs to indicate the current mode (Colors can be set to any value when PWM pins are available).
Reset-From-Pad (AKA In-Game-Reset AKA IGR): Press Start + A + B + C.
Supports consoles with both active-high and active-low reset signals by autosensing (i.e.: all console revisions!).
Uses cheap Atmel AVR microcontrollers (ATtiny's, ATmega's, or even a full Arduino board) - If flashed on an ATtinyX4(A), it is pin-to-pin compatibile with the D4s/Seb mod.
Even though default settings are recommended, everything can be customized to taste.
Last but not least, it is Open Source and Free Software!
If you are interested in trying it out, check out GitHub - SukkoPera/MegaDrivePlusPlus: Universal Region mod, 50/60 Hz switch and In-Game-Reset (IGR) for Sega Mega Drive (AKA Genesis)
