const int analogInPin1 = A0;
static unsigned char adcval;
pinMode(13, OUTPUT);
ADCSRA = 0; // clear ADCSRA register
ADCSRB = 0; // clear ADCSRB register
ADMUX |= (0 & 0x07); // set A0 analog input pin
ADMUX |= (1 << REFS0); // set reference voltage
ADMUX |= (1 << ADLAR); // left align ADC value to 8 bits from ADCH register
// sampling rate is [ADC clock] / [prescaler] / [conversion clock cycles]
// for Arduino Uno ADC clock is 16 MHz and a conversion takes 13 clock cycles
//ADCSRA |= (1 << ADPS2) | (1 << ADPS0); // 32 prescaler for 38.5 KHz
ADCSRA |= (1 << ADPS2); // 16 prescaler for 76.9 KHz
//ADCSRA |= (1 << ADPS1) | (1 << ADPS0); // 8 prescaler for 153.8 KHz
ADCSRA |= (1 << ADATE); // enable auto trigger
ADCSRA |= (1 << ADIE); // enable interrupts when measurement complete
ADCSRA |= (1 << ADEN); // enable ADC
ADCSRA |= (1 << ADSC); // start ADC measurements
ISR(ADC_vect)
adcval = ADCH; // read 8 bit value from ADC
Serial.write(adcval);
// Following code to generate ref signal at pin 13 @ 50HZ. You can connect A0 to see the waveform in PCScope.exe
ctr++;
if(ctr>117) //117=10.03ms
ctr=0;
flag_tog = !flag_tog;
digitalWrite(13, flag_tog);
this is the code of aurdino based osciloscope
but problem is that it gives only positive cycle instead of showing both positive and negative cycles.
help me please if any solution available??
