Hello all!
This is my first post!
My name is Omri, and Im 16 years old.
A month ago I bought the Arduino Duemilanove.
I got a previews interest at BF language ,and saw the BrainDuino,
I decided to write my own interpreter (not based on others interpreters).
This is my first real arduino program(but not the first one...),
the program uses the eeprom the storage the commands,
and the serial monitor as i/o.
Here is the full code:
#include <EEPROM.h>
int n = ???; //how meny memory cells you would like to use?
unsigned char value[n]; //create n memory cells (you need to change "n" so it will be the same as int n)
int i = 0; //data pointer
char command; //storage the command from the eeprom
int instruction_pointer = 0; //instruction pointer
boolean x = false;
int y = 0;
do //put the value zero in all of the memory cells
value[i] = 0;
i++;
while(i < n);
i = 0;
Serial.print("hello");
Serial.print("\n");
//-----------put your BF code into the arduino eeprom memory-------------------
EEPROM.write(0, '+'); //write brainfuck code to the arduinos eeprom
EEPROM.write(1, '['); //write brainfuck code to the arduinos eeprom
EEPROM.write(2, ','); //write brainfuck code to the arduinos eeprom
EEPROM.write(3, '.'); //write brainfuck code to the arduinos eeprom
EEPROM.write(4, ']'); //write brainfuck code to the arduinos eeprom
//-----------this is a "cat" example-------------------------------------------
Serial.print("the code:");
Serial.print("\n");
command = EEPROM.read(i);
while(command == '>' || command == '<' || command == '+' || command == '-' || command == ',' || command == '.' || command == '[' || command == ']')
Serial.print(command);
i++;
i = 0;
Serial.print("\n");
Serial.print("start...");
Serial.print("\n");
Serial.print("user interface:");
Serial.print("\n");
Serial.print(">>");
Serial.print("\n");
command = EEPROM.read(instruction_pointer); //read the command
switch (command) //cheack what command is it
case '>' :
++i;
case '<':
--i;
case '+':
++value[i];
case '-':
--value[i];
case '.':
if(value[i] == 10)
Serial.println(">>"); //new line (10 at the ascii chart)
Serial.println(value[i]);
case ',':
while(x == false)
if (Serial.available() > 0)
value[i] = Serial.read();
x = true;
x = false;
case '[': if(value[i] == 0)
y = 1;
while(y != 0)
++instruction_pointer;
if(command == '[')
y++;
else if(command == ']')
y--;
case ']':
if(value[i] != 0)
y = 1;
while(y != 0)
--instruction_pointer;
if(command == ']')
y++;
else if(command == '[')
y--;
default:
Serial.print("error:end of the progrem"); //didnt got a command
return;
++instruction_pointer; //next command
I will be glad to get comments about it,
thanks,
Omri ![]()
P.S.
for these who doesnt know what BF is:
