Arduino Bitwise operation
unsigned char i,w;
long int y;
 w=(y>>=0);
	  for(i=0; i<8; i++)
	    digitalWrite(BitData, (w>>i)&0x01);
	    digitalWrite(CLK, 1);
	    digitalWrite(CLK, 0);
Help me to understand this piece of code. -
(1) w=(y>>=0). What this mean ? >> is shift right. But what is mean by y>>=0
(2) digitalWrite(BitData, (w>>i)&0x01) as per the manual , BitData is pin and (w>>i)&0x01 is the data. What is the output of this line. Please help.
The first question: it looks wrong. There is no legitimate meaning. There are whole websites dedicated to obscure scam-code like this.
The second question: What they are doing there, is shifting w to the right, and “and” ing with 1. That is, 00000001. That will result in a one or a zero depending on the corresponding bit of w which you shifted there. That is a normal method of outputing the bits of w, one bit at a time, to a serial output of any kind.
Thanks for your quick reply.
I am trying to understand AD9850 library for arduino. Here is the complete code. Why we need to AND every bit serially send to a device ? If we want to send 01010101, if we are AND every bit, the output data will be 10101010 which is totally wrong.
AD8950.cpp
**  Device: AD9850/9851                                             **
**  File:   EF_AD9850.cpp				                                    **
**  Created by ElecFreaks Robi.W /28 Oct 2011                       **
**  Description:                                                    **
**  This file is a sample code for your reference.About AD9850/9851 **
**  module use on Arduino with serial mode. And then show the       **
**  square wave and sine wave by LXARDOSCOPE which is an free       **
**  Arduino based oscilloscope Linux, using the Xforms library.     **
**  This demo code is free software; you can redistribute it and/or **
**  modify it under the terms of the GNU Lesser General Public	    **
**  License as published by the Free Software Foundation; either    **
**  version 2.1 of the License, or (at your option)   		    			**
**  any later version.						    															**
**  Copyright (C) 2011 ElecFreaks Corp.                     	    	**
**  http://www.elecfreaks.com                                       **
#include "EF_AD9850.h"
EF_AD9850::EF_AD9850(int D_CLK, int D_FQUP, int D_REST, int D_BitData)
		pinMode(D_REST, OUTPUT);
   	pinMode(D_FQUP, OUTPUT);
   	pinMode(D_CLK , OUTPUT);
   	pinMode(D_BitData, OUTPUT);
   	CLK = D_CLK;
   	FQUP= D_FQUP;
   	REST= D_REST;
   	BitData = D_BitData;
void EF_AD9850::init(void)
		digitalWrite(REST, 0);
   	digitalWrite(FQUP, 0);
   	digitalWrite(BitData, 0);
void EF_AD9850::reset(void)
	  //Reset signal
	  digitalWrite(REST, 1);
	  //Clk  signal
	  //Fq-up signal
	  digitalWrite(FQUP, 1);
void EF_AD9850::wr_serial(unsigned char w0,double frequence)
		unsigned char i,w;
	  long int y;
	  double x;
	  //Calculate the frequency of the HEX value
	  x=4294967295/125;//Suitable for 125M Crystal
	  frequence=frequence/1000000;
	  frequence=frequence*x;
	  y=frequence;
	  //write w4
	  w=(y>>=0);
	  for(i=0; i<8; i++)
	  //write w3
	  w=(y>>8);
	  for(i=0; i<8; i++)
	  //write w2
	  w=(y>>16);
	  for(i=0; i<8; i++)
	  //write w1
	  w=(y>>24);
	  for(i=0; i<8; i++)
	  //write w0
	  w=w0;
	  for(i=0; i<8; i++)
void EF_AD9850::wr_parrel(unsigned char w0,double frequence)
**EF_AD9850.h **
**  File:   EF_AD9850.h					                                    **
**  Description:                                                    **
#ifndef __EF_AD9850_H__
#define __EF_AD9850_H__
#include "WProgram.h"
#include <avr/pgmspace.h>
class EF_AD9850{
	public:
		 EF_AD9850(int D_CLK, int D_FQUP, int D_REST, int D_BitData);
     void init(void);
     void reset(void);
     void wr_serial(unsigned char w0,double frequence);
     void wr_parrel(unsigned char w0,double frequence);
   private:
     int BitData, FQUP, REST, Mode, CLK;
#endif
anishpsla:
Presumably the original author thought that was right in that situation. Perhaps they understand what is necessary better than you do. Does it actually work?
w=(y>>=0); equals w = (y = y >> 0) equals w = (y = y) equals w = y
