Arduino BLE Sense _ SD Module - Initializing SD card...initialization failed
Hi guys I have hooked up an SD module to my BLE Sense, CS is pin 10 and changed in the Card Info code, however I continually get the following message. SD card was formatted with SD Card Formatter and the module is brand new. Something else that is a bit weird in IDE beta it jumps from COM26 to 25 midway through upload and then errors saying no board on 26.
I switched back to IDE 1.8.13 and now it uploads fine but still get the same following error. (I have obviously checked wiring etc)
Initializing SD card...initialization failed. Things to check:
  • is a card inserted?
  • is your wiring correct?
  • did you change the chipSelect pin to match your shield or module?
I have seen this issue a lot but most of the topics were not answered but locked.
Got the problem, although I had seen this particular module being powered by 3.3v in other posts, it actually did require 5v. I made the solder bridge on the VUSB pads and fired it up and voila :slight_smile:
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Clusters: 485936
Blocks x Cluster: 64
Total Blocks: 31099904
Volume type is: FAT32
Volume size (Kb): 15549952
Volume size (Mb): 15185
Volume size (Gb): 14.83
Files found on the card (name, date and size in bytes):
SYSTEM~1/ 2021-07-10 03:22:42
INDEXE~1 2021-07-10 03:40:18 76
WPSETT~1.DAT 2021-07-10 03:40:26 12
IM106_0.JPG 2021-07-08 02:14:34 1832955
IM006_1.JPG 2021-07-08 02:14:44 558385
IM020_1.JPG 2021-07-08 02:14:38 540867
IM024_1.JPG 2021-07-08 02:14:42 540579
IM026_1.JPG 2021-07-08 02:14:44 555069
IM028_1.JPG 2021-07-08 02:14:40 562406
IM031_1.JPG 2021-07-08 02:14:40 541775
IM035_0.JPG 2021-07-08 02:14:38 1845986
IM041_0.JPG 2021-07-08 02:14:40 1815300
IM047_0.JPG 2021-07-08 02:14:42 1849404
IM053_1.JPG 2021-07-08 02:14:44 1898825
IM057_1.JPG 2021-07-08 02:14:40 1824693
IM060_1.JPG 2021-07-08 02:14:34 1788583
IM063_1.JPG 2021-07-08 02:14:36 1813905
IM069_0.JPG 2021-07-08 02:14:30 1813423
IM074_0.JPG 2021-07-08 02:14:42 1710829
IM088_0.JPG 2021-07-08 02:14:40 1870880
IM095_0.JPG 2021-07-08 02:14:44 1251787
IM099_0.JPG 2021-07-08 02:14:38 1833956
IM101_0.JPG 2021-07-08 02:14:30 1825249
