Arduino blink
The blink without delay code doesn't seem to be working properly..need help!
int led=8;
long currmills;
long prevmills;
long duration=1000;
int state;
pinMode(led,OUTPUT);
prevmills=0;
digitalWrite(led,LOW);
currmills=millis();
if(currmills - prevmills >=duration)
prevmills=currmills;
if(led==LOW)
state=HIGH;
state=LOW;
digitalWrite(led,state);
Serial.println(state);
By not working..i mean the serial monitor shows that the led is always low!!
Does the led blink?
Nope..it doesnt!
  if(led==LOW)
led is a variable that appears to hold the pin value. You should be comparing your state variable. A more descriptive name like ledPin would have made this error more obvious.
Your timing variables should also be unsigned long.
Bad mistake..thanks for pointing that out!
