Arduino blinking LED disruption by LCD Refresh
Hello, I'm preety new to Arduino programing. I'm creating one of my first projects and I have a problem with a very simple code.
Every 20ms i'm sending pulsed signal to the LED - very easy and it's working as intented. But... After adding an LCD display to the project on which I want to display data in the loop (refreshing every 1 second), interference appears that affects the LED blinking frequency.
Each time the LCD display is being refreshed (LCDRefreshTime), additional LED flash occurs. How to prevent this?
I'm using Arduino Uno R3 and 1602 LCD display ( HD44780). Also i'm using LiquidCrystal library to control the LCD display.
Here is my test code:
LiquidCrystal_I2C lcd(0x27,16,2);
unsigned long LCDTime = 0;
unsigned long LCDSavedTime = 0;
const int LCDRefreshTime = 1000; // 1s refresh time
const int outPin = 9;
  lcd.backlight();                 // lcd backlight ON i2c
  lcd.init();                           // initialize the lcd  i2c
  lcd.home();                      // lcd coursor to 0,0
  lcd.print("Initializing...");
  pinMode(outPin, OUTPUT);
  lcd.clear();
  TestPulse();
  DisplayData();
void TestPulse() {
  digitalWrite(outPin, LOW);
  delay (20);
  digitalWrite(outPin, HIGH);
  delay (20);
void DisplayData () {
  LCDTime = millis();
  if (LCDTime - LCDSavedTime >= LCDRefreshTime) {
     LCDSavedTime = LCDTime;
     lcd.clear();
     lcd.setCursor(0, 0);
     lcd.print("Line 1: ");
     lcd.setCursor(0, 1);
     lcd.print("Line 2: ");
Consider having the Arduino doing the 25Hz LED pulses in the background with tone(outPin,25) . Add that call to setup() and dispense with TestPulse() entirely.
