Arduino BlinkM and 2x PIR Sensors
So some insight before the problem so you know where i'm at.
I connected to Arduino Analog 5-1 arduino, like it says to use in communicator
PIR x1 to 3v3 ground and Digital3 PIR x2 to 3v3 ground and Digital4
What i want to do is have each PIR when triggered to produce a different color so i know which PIR was triggered
I plan on color coding some rooms in my house, so when motion is recorded in blue room, the blinkm will produce blue in the bedroom. So i know where motion is when it occurs.
So, that was the background. What is the problem?
Well i’m having issues with the code, i used the blinkm code, and pir code, for a single pir
Works fine, when pir gets triggered it applies power to blinkm
Now setting up 2 pir’s and i want color specific blinkm response dependant if pir 1 or pir 2 is triggered…
So i grabbed the code from previous version and tried tweaking, blah i dont think i’m a programmer :slight_smile:
so code is where i’m having an issue.
Post your code.
