Hi Everyone,
I've been stuck with an issue for a few days and cannot figure out what's wrong...I have a bluetooth module (Hm-10) connected to my Uno, and the bluetooth works.
I've ran code to output to the pins 9-12 and have verified the outputing also works for turning on 4 auxilery LEDs.
The problem is now when I try to use bluetooth AND turn on the auxiliary LEDs. The bluetooth is receiving information, and the IF statements are also triggering (I can see in console), BUT the problem is that the Auxiliery LEDs are not turning on.
see code snippet below.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7,8);
int ledpin=13;
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
mySerial.begin(9600);
pinMode(ledpin,OUTPUT);
int i;
if (mySerial.available())
i=mySerial.read();
Serial.println("DATA RECEIVED:");
if(i=='0')
//This is the problem because LED won't turn on
Serial.println("Running Aux 9");
digitalWrite(9, HIGH);
delay(100); // wait for a second
digitalWrite(9, LOW);
delay(100);
if(i=='1')
Serial.println("Running Aux 10");
digitalWrite(10, HIGH);
digitalWrite(10, LOW);
delay(100);
if(i=='2')
Serial.println("Running Aux 11");
digitalWrite(11, HIGH);
digitalWrite(11, LOW);
delay(100);
if(i=='3')
Serial.println("Running Aux 12");
digitalWrite(12, HIGH);
digitalWrite(12, LOW);
delay(100);
The above is the set-up that is not working...Initially I thought maybe bluetooth and LEDs won't work together because bluetooth sucks too much energy, so I provided an external power source for the bluetooth module and even then the LEDs won't turn on.
I ran the below code and the LEDs turn on, so I don't know why I can't turn them on using the Bluetooth code above:
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(13, OUTPUT);
pinMode(9, OUTPUT);
// the loop function runs over and over again forever
Im out of ideas on what could be wrong...thoughts?
