hi,
i got my arduino bt boards today and
i tried to hook it up under ubuntu with little success so far
maybe somebody has an idea how to proceed:
first i did:
erich@pupu:~$ hcitool scan
Scanning ...
00:15:A0:80:FE:1E Nokia N70
00:07:80:82:1F:35 ARDUINOBT
00:12:62:DB:EA:E7 Erich
to find the bt id (ARDUINOBT)
then i edited:
erich@pupu:~$ sudo vi /etc/bluetooth/rfcomm.conf
RFCOMM configuration file.
example:
rfcomm0 {
bind yes;
Bluetooth address of the device
device 00:07:80:82:1F:35;
RFCOMM channel for the connection
channel 1;
Description of the connection
comment "ARDUINOBT";
and after:
erich@pupu:~$ sudo /etc/init.d/bluez-utils restart
now i have a linux bt serial device rfcomm0 which shows with
erich@pupu:~$ rfcomm
rfcomm0: 00:07:80:82:1F:35 channel 1 clean
i edited then the preferences text in ~/.arduino/preferences.txt
and changed the following:
serial.port=/dev/rfcomm0
and
serial.download_rate=115200
if i now start the ide, compile a program and upload it, i get a:
/dev/rfcomm0 permission denied.
in the ide message window and command line.
the output of rfcomm changes to:
rfcomm0: 00:07:80:82:1F:35 channel 1 closed
but i m in group dialout and the rights are the same like for example for /dev/ttyUSB0 which
works without problems on the usb arduino board. also chip is set to atm168 and serialmonitor to 115200.
thx a lot
erich
ps: the bord works fine under windows !
