Hi! I'm trying to make a bluetooth app for my arduino project. I'm trying to display the data from 2 DHT22 sensors and one MQ-2 in the app for now.
I'm designing the App in MIT App Inventor and when I tried running it, it doesn't show any value. This is my code and my app (temporarily because I have to develop the second screen and the LED functionality isn't added yet).
#include "DHT.h" // libraria pentru senzorii de temperatura
#include <MQ2.h> //libraria pentru senzorul de gaz
int gaz = A0;
int lpg, co, smoke;
MQ2 mq2(gaz); //s-a creat obiectul corespunaztor senzorului de gaz
DHT dht22in(8, DHT22); //s-au creat obiectele pentru senzori si li s-au atribuit pinii corespunzatori
DHT dht22out(9, DHT22);
int cm = 0;
String temp;
String hum;
String gaze;
char caracter;
/*long readUltrasonicDistance(int triggerPin, int echoPin)
pinMode(triggerPin, OUTPUT); // Clear the trigger
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
// Sets the trigger pin to HIGH state for 10 microseconds
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
// Reads the echo pin, and returns the sound wave travel time in microseconds
return pulseIn(echoPin, HIGH);
void setup(void) {
dht22in.begin();
dht22out.begin();
mq2.begin();
//Serial.println("Sensors are warming up!");
delay(2000);
void loop(void) {
int temp1 = dht22in.readTemperature();
int temp2 = dht22out.readTemperature();
int hum1 = dht22in.readHumidity();
int hum2 = dht22out.readHumidity();
float* values= mq2.read(false); //set it false if you don't want to print the values in the Serial
lpg = mq2.readLPG();
co = mq2.readCO();
smoke = mq2.readSmoke();
/* cm = 0.01723 * readUltrasonicDistance(7, 6);
if (cm<50) {
Serial.print(cm);
Serial.print(" cm");
delay(1000); // Wait for 100 millisecond(s)
Serial.println(" ");
} else Serial.println(" ");
if(Serial.available()) {
caracter = Serial.read();
if(caracter == 'P'){temp = (String) temp1 + ","+ (String) temp2;
Serial.println(temp);};
if(caracter == 'U'){hum = (String) hum1 + ","+ (String) hum2;
Serial.println(hum);};
if(caracter == 'G'){gaze = (String) lpg + "," + (String) co+ "," + (String) smoke);
Serial.println(gaze);
I suggest that, for development at least, you use a different serial port for the Bluetooth module. Save the main hardware serial port (USB) for program upload, program output and debug prints.
Then use on of the extra serial ports (Serial1, Serial2 or Serial3) for the Bluetooth module.
Your code modified to use Serial1 for Bluetooth module. Mega pin 18 (TX1) to BT RX (through voltage dibvider), Mega RX1 to BT TX. The incoming from the Bluetooth module is then printed to serial monitor. Untested.
int gaz = A0;
int lpg, co, smoke;
int cm = 0;
String temp;
String hum;
String gaze;
char caracter;
/* long readUltrasonicDistance(int triggerPin, int echoPin)
void setup(void)
Serial1.begin(9600); // ********* open serial1 for Bluetooth module
dht22in.begin();
dht22out.begin();
mq2.begin();
delay(2000);
void loop(void)
float* values = mq2.read(false); //set it false if you don't want to print the values in the Serial
co = mq2.readCO();
if (cm<50) {
Serial.print(cm);
if (Serial1.available()) // ******** change to Serial1
caracter = Serial1.read(); // ******** change to Serial1
// print incoming character to serial monitor. The < and > will show
// if there is an invisible character (\r and/or \n) sent.
Serial.print("incoming character <");
Serial.print(caracter);
Serial.println(">");
if (caracter == 'P')
temp = (String) temp1 + "," + (String) temp2;
if (caracter == 'U')
hum = (String) hum1 + "," + (String) hum2;
if (caracter == 'G')
gaze = (String) lpg + "," + (String) co + "," + (String) smoke);
Post the output from serial monitor (incoming character).
You may want to reconsider using the String class. There is potential for memory corruption using Strings. Use c_strings instead.
