Arduino Bluetooth Issue
I am connecting to my ardunio via a Bluetooth Bee (Actually , its a Seeedstudio 'bee') . Anyhow , I send a command to turn on/off an LED on pin 3 . The problem I am having is that it only seems to work 75% of the time. I can turn it on and off but sometimes I have to enter a/b several times , even if I am 1 foot away from the device. Could this be a hardware issue? Please let me know if any problems are obvious in my code , maybe a delay?
Thanks in advance!
#include <SoftwareSerial.h>
#define RxD 12
#define TxD 13
#define DEBUG_ENABLED  1
SoftwareSerial blueToothSerial(RxD,TxD);
int ledpin1 = 3;
    pinMode(ledpin1, OUTPUT);
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    setupBlueToothConnection();
  if(blueToothSerial.read() == 'a')
    digitalWrite(ledpin1, HIGH);
    blueToothSerial.println(" LED on pin one is now on");
  if(blueToothSerial.read() == 'b')
    digitalWrite(ledpin1, LOW);
    blueToothSerial.println(" LED on pin one is now off");
void setupBlueToothConnection()
    blueToothSerial.begin(38400);
    sendBlueToothCommand("\r\n+STWMOD=0\r\n");
    sendBlueToothCommand("\r\n+STNA=TestMode\r\n");
    sendBlueToothCommand("\r\n+STAUTO=0\r\n");
    sendBlueToothCommand("\r\n+STOAUT=1\r\n");
    sendBlueToothCommand("\r\n +STPIN=0000\r\n");
    delay(2000);
    sendBlueToothCommand("\r\n+INQ=1\r\n");
    delay(2000);
void CheckOK()
  char a,b;
  while(1)
    if(blueToothSerial.available())
    a = blueToothSerial.read();
    if('O' == a)
      while(blueToothSerial.available())
         b = blueToothSerial.read();
      if('K' == b)
  while( (a = blueToothSerial.read()) != -1)
void sendBlueToothCommand(char command[])
    blueToothSerial.print(command);
    CheckOK();
If the character in the buffer is a b, the first statement will read it, and decide that it is not an a. The next statement will read the next, possibly non-existant, character, and decide that it is not a b.
You need to test that there is a character to read first. Then, you need to read and store the character. Then, you need to test the stored character. Do NOT read every time.
