When I plug in the battery to the L298n servo driver, it makes a buzzing sound and the motors don’t respond to commands from the mobile app. The noise stops when I unplug the in1, in2, in3, in4 pins
My project is to make a robot arm and place it on wheels, then control everything through bluetooth using ‘Arduino Bluetooth Control’ by Giumig apps. These are my materials:
3 MG996R servos
2 gear motors from 2WD kit
HC-05 bluetooth module
L298N motor driver
Turnigy 2S 7.4V 2200 mAh Li-po
ARDUINO NANO (clone)
Vivo 180 (Android)
I uploaded this code:
Robot arm on wheels code
I’m using ‘Arduino Bluetooth control’ by Giumig apps to control the robot’s wheels:
Any help or suggestions would be much appreciated!
Please post the code here, using code tags.
Please post schematics.
Here is the code:
#include <SoftwareSerial.h> // TX RX software library for bluetooth
#include <Servo.h> // servo library
Servo myservo1, myservo2, myservo3; // servo name
int bluetoothTx = 0; // bluetooth tx to 10 pin
int bluetoothRx = 1; // bluetooth rx to 11 pin
int motorOne = 3;
int motorOne2 = 4;
int motorTwo = 5;
int motorTwo2 = 6;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
//initial motors pin
char command;
char Value;
myservo1.attach(3); // attach servo signal wire to pin 9
myservo2.attach(5);
myservo3.attach(6);
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
bluetooth.begin(9600);
while (bluetooth.available() > 0) {
Value = Serial.read();
Serial.println(Value);
if ( Value == 'F') {
// Robo Pet Run Forward
digitalWrite(motorOne, HIGH);
digitalWrite(motorOne2, LOW);
digitalWrite(motorTwo, HIGH);
digitalWrite(motorTwo2, LOW);
} else if (Value == 'B') {
//Robo Pet Run Backward
digitalWrite(motorOne, LOW);
digitalWrite(motorOne2, HIGH);
digitalWrite(motorTwo, LOW);
digitalWrite(motorTwo2, HIGH);
} else if (Value == 'L') {
//Robo Pet Turn Left
} else if (Value == 'R') {
//Robo Pet Turn Right
} else if (Value == 'S') {
//Robo Pet Stop
//Read from bluetooth and write to usb serial
if(bluetooth.available()>= 2 )
unsigned int servopos = bluetooth.read();
unsigned int servopos1 = bluetooth.read();
unsigned int realservo = (servopos1 *256) + servopos;
Serial.println(realservo);
if (realservo >= 1000 && realservo <1180) {
int servo1 = realservo;
servo1 = map(servo1, 1000, 1180, 0, 180);
myservo1.write(servo1);
Serial.println("Servo 1 ON");
delay(10);
if (realservo >= 2000 && realservo <2180) {
int servo2 = realservo;
servo2 = map(servo2, 2000, 2180, 0, 180);
myservo2.write(servo2);
Serial.println("Servo 2 ON");
delay(10);
if (realservo >= 3000 && realservo <3180) {
int servo3 = realservo;
servo3 = map(servo3, 3000, 3180, 0, 180);
myservo3.write(servo3);
Serial.println("Servo 3 ON");
delay(10);
system
Closed
February 27, 2023, 1:32pm
4
