Any Idea?
Arduino: 1.8.15 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries R:\RhysinFolder\Mego Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10815 -build-path C:\Users\jm\AppData\Local\Temp\arduino_build_772461 -warnings=none -build-cache C:\Users\jm\AppData\Local\Temp\arduino_cache_872526 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\jm\AppData\Local\Temp\arduino_modified_sketch_869593\sketch_may27a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries R:\RhysinFolder\Mego Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10815 -build-path C:\Users\jm\AppData\Local\Temp\arduino_build_772461 -warnings=none -build-cache C:\Users\jm\AppData\Local\Temp\arduino_cache_872526 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\jm\AppData\Local\Temp\arduino_modified_sketch_869593\sketch_may27a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\jm\AppData\Local\Temp\arduino_build_772461\sketch\sketch_may27a.ino.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0]
ResolveLibrary(SoftwareSerial.h)
-> candidates: [SoftwareSerial@1.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\jm\AppData\Local\Temp\arduino_build_772461\sketch\sketch_may27a.ino.cpp" -o nul
Alternatives for BlynkSimpleStream.h: [Blynk@1.0.0]
ResolveLibrary(BlynkSimpleStream.h)
-> candidates: [Blynk@1.0.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IR:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk\src" "C:\Users\jm\AppData\Local\Temp\arduino_build_772461\sketch\sketch_may27a.ino.cpp" -o nul
Alternatives for functional: []
ResolveLibrary(functional)
-> candidates: []om R:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:38:0,
from R:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from R:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk\src/Adapters/BlynkSerial.h:18,
from R:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk\src/BlynkSimpleStream.h:18,
from C:\Users\jm\AppData\Local\Temp\arduino_modified_sketch_869593\sketch_may27a.ino:42:
R:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk\src/Blynk/BlynkConsole.h:20:10: fatal error: functional: No such file or directory
#include
compilation terminated.
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
Using library Blynk at version 1.0.0 in folder: R:\RhysinFolder\Mego Documents\Arduino\libraries\Blynk
exit status 1
Error compiling for board Arduino Uno.
