Arduino Board connections
What is the function of the 2 TWI OUT 5 OUT 6 IN 2 and IN 3 male receptacles on the Arduino NDof Shield?
Google is our friend:
http://www.ohmeron.be/media/files/Downloads/A000070.pdf
Well, it took awhile but someone actually had a truncated data sheet for the A000070 board with a reasonable description of the Tinkerkit compatible male connectors. TWI = Two Wire Inputs, not clear but looks like they could be I2C connections with GND, PWR and two data pins. Out 6 and Out 5 connect to digital pins 6 and 5 respectively IN2 and IN 3 connect to Analog pins 2 and 3 respectively
For a newbe this does seem harder than it should but I guess that is what learning is all about.
Thanks.
It's meant to make things easier (though the apparent difficulty of locating docs seems to run contrary to that) - those headers are two I2C headers (TWI is what atmel calls I2C - I think I2C is trademarked or something), two digital pins, and two analog pins - and each header also has power and ground. Note that despite being marked "in", those analog pins are fully functional digital pins as well as being able to do analogRead() - the way arduino documentation presents it doesn't always make this clear.
DrAzzy: It's meant to make things easier (though the apparent difficulty of locating docs seems to run contrary to that) - those headers are two I2C headers (TWI is what atmel calls I2C - I think I2C is trademarked or something), two digital pins, and two analog pins - and each header also has power and ground. Note that despite being marked "in", those analog pins are fully functional digital pins as well as being able to do analogRead() - the way arduino documentation presents it doesn't always make this clear.
Thanks for the thoughtful response. Seems there is no big advantage to using these vs. the header pin sockets for my purposes but good to know what they are. I looked for Tinkerkit info and they seem to be off the grid as well as Arduino.org .
Now for trying to figure out what pins on the shield are tied up soo I can still use my LCD to display output from the shield.
