Hi, I need some help with the next problem: I’m doing a project to control a water pump, but each time that I execute a subroutine to set a parameter, the board “crashes”, sometimes just restarts, and sometimes it go nuts, enabling and disabling random outputs. I’ve created a new file with just the subroutine to test it, and now the board doen’t crashes, but keeps randomly enabling and disabling the pump output pin even without a digitalWrite function on the code.
I’ve attached the file of the full code because it’s too long to post it here, but here is the subroutine code:
#include <LiquidCrystal.h>
#include <EEPROM.h>
float distancia;
float tiempo;
int trigger=4; //Trigger pin
int eco=5; //Echo pin
int nivMin;
int nivMax;
float area;
float porcentaje;
int bomba = A5; //output attached to the pump relay
int outBomba;
int setPoint; //% to start the pump
int sensorLleno = 3;
int sensorBomba = 2;
int x=0;
int tiempoProteccion=5; //Protection time in seconds
int izquierda=A4;
int derecha=A3;
int menu=A2;
int salir=A1;
int menus=1;
int counter=0;
int proteccion; //enables or disables the protection (0 or 1)
LiquidCrystal lcd(13,12,10,9,8,7); //( RS, EN, d4, d5, d6, d7)
pinMode (6,OUTPUT); //Screen light
analogWrite (6,255); //PWM brightness control
lcd.begin(16, 2); //LCD 16x2
// lcd.setCursor(3, 0);
//lcd.print("Bienvenido");
//delay(2000);
pinMode(4,OUTPUT); //trigger
pinMode(5,INPUT); //echo
pinMode(bomba,OUTPUT); //pump
pinMode(sensorLleno,INPUT);
pinMode(sensorBomba,INPUT);
pinMode(izquierda,OUTPUT);
pinMode(derecha,OUTPUT);
pinMode(menu,OUTPUT);
pinMode(salir,OUTPUT);
//EEPROM.put(4,1); Not using it now
EEPROM.get(0,nivMin);
EEPROM.get(2,nivMax);
EEPROM.get(4,proteccion);
EEPROM.get(6,setPoint);
EEPROM.get(8,tiempoProteccion);
Serial.println(nivMin);
Serial.println(nivMax);
Serial.println(proteccion);
Serial.println(setPoint);
Serial.println(tiempoProteccion);
lcd.clear();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Ajuste el tiempo");
if (tiempoProteccion>0){
lcd.setCursor(0, 1);
lcd.print("<<");
if (tiempoProteccion<=200){
lcd.setCursor(14, 1);
lcd.print(">>");
if (tiempoProteccion==0){
lcd.setCursor(5, 1);
lcd.print("Apagada");
else{
lcd.setCursor(2, 1);
lcd.print(tiempoProteccion);
lcd.setCursor(6, 1);
lcd.print("Segundos");
if (digitalRead(derecha)==HIGH){
while (digitalRead(derecha)==HIGH){
delay(100);
if (tiempoProteccion<250){
tiempoProteccion++;
else if (digitalRead(izquierda)==HIGH){
while (digitalRead(izquierda)==HIGH){
delay(100);
tiempoProteccion--;
if (digitalRead(salir)==LOW){
delay(100);
loop();
while (digitalRead(salir)==HIGH){
delay(100);
// calibracion(); returns to the selection menu subroutine
This code has all the variables from the main code, and sorry for not translating the variables to english, but I don’t want to ruin something (also I’m pretty tired…). Thanks for your attention.
Proyecto_bomba.ino (6.92 KB)
