Arduino Board does not see Bluetooth module
Arduino Board does not see Bluetooth module. Board Arduino UNO, Bluetooth module OPEN-SMART (JDY-32-SPP.),CH340G driver, programmer AVRISPmkll,Board is powered from 5v, the RXD pin is number 5, and the TXD pin is number 3,digital PWM contacts numbers 11,10, 9, 6, 5, 3. Оther information - BN: Unknown fee, VID: 1A86, PID: 7523, SN: Download any sketch to use.
Плата Arduino UNO, Bluetooth модуль OPEN-SMART (JDY-32-SPP.), драйвер СН340G, программатор AVRISPmkll ,питается плата от 5v, пин RXD имеет номер 5, а пин TXD имеет номер 3,
цифровые пины ШИМ имеют номера 11,10, 9, 6, 5, 3. Информация о плате - BN: Неизвестная плата, VID: 1A86, PID: 7523, SN: Загрузить любой скетч, для использования
And just in case the sketch
И на всякий случай скетч
#define motorAgo 11
#define motorBgo 10
#define motorAbac 9
#define motorBbac 6
#include <SoftwareSerial.h>
SoftwareSerial mySerial(5, 3); // RX, TX
int command;
  pinMode (motorAgo, OUTPUT);
  pinMode (motorBgo, OUTPUT);
  pinMode (motorAbac, OUTPUT);
  pinMode (motorBbac, OUTPUT);
void goAhead() { // едем вперед
  digitalWrite (motorAgo, HIGH);
  digitalWrite (motorBgo, HIGH);
  digitalWrite (motorAbac, LOW);
  digitalWrite (motorBbac, LOW);
void goBack() {// едем назад
  digitalWrite (motorAgo, LOW);
  digitalWrite (motorBgo, LOW);
  digitalWrite (motorAbac, HIGH);
  digitalWrite (motorBbac, HIGH);
void stopRobot() { // останавливаемся
void goLeft() { // поворачиваем налево
void goRight() { // поворачиваем направо
  if (Serial.available() > 0)
    char command = Serial.read();
    switch (command) {
      case 'f': goAhead(); break;
      case 'b': goBack(); break;
      case 's': stopRobot(); break;
      case 'l': goLeft(); break;
      case 'r': goRight(); break;
The command
Serial.begin(…);
at the nominated baud rate is missing, and check the wiring Arduino<>Bluetooth as well.
Аnd where to put this line?
It needs to be in the setup part. You also did not start your SoftwareSerial called mySerial(). Didn't check what you need to do with it but you most likely need to init that too. Use Serial.begin(desiredBAUDrate) and mySerial.begin(desiredBAUDrate) in your setup part.
EDIT:
What do you do with your SoftwareSerial actually. I don't think you are using it.
I tried and realized that the module does not have electricity,how to fix it?
Connect VCC to 3.3V, you require at least 100mA on that pin. Connect ground to ground. If you supply your module from a different power source, bridge Arduino's and module's grounds. That should power up the module.
Is there any way to check if the module works at all?
Аnd I was wrong modelul not HC-08, and JDY-32-SPP.
Well, I guess you could lean some power against it and see if the light is on. That would go quite some way to a conclusion. Then you might see if you can sniff it with a phone to see if Bluetooth is working, it probably will be. Finally connect Arduino to it in the proper manner, and serial print "hello".
It really isn't hard.
