Arduino Board Options
Hi, I am currently working on an Arduino build that will utilize two motors (3-6VDC; 150mA), one distance sensor (5V input; 3V output; 30mA), 4 solenoids (24VDC; 13-14.5 psi each), and 4 single action cylinders. With one input and and 6 outputs what kind of arduino circuit board could handle this amount of voltage and current or should I use multiple boards and if so which ones?
Any Arduino would do but none handle all that power. They are microcontrollers. The peripherals would be powered separately.
A Nano would do the job, or an Uno, there's nothing special here unless you've not told us about future expansion plans.
But, power only the distance sensor with your Arduino. You will need to use motor drivers and relay boards, or solid state output drivers, for the solenoids and cylinders. Power should be from a separate power supply. Don't forget transient suppression diodes on the solenoids, they protect both your switching circuits, and the power supply itself.
Once you get a bit further along, reply here, in this thread, with a proposed schematic and parts list(include tech spec links for the solenoids, motor driver, and cylinders(what drives them, more solenoids?), and we can discuss what you've designed before you purchase anything.
