Arduino board resets after reconnecting with USB-port
Hello forum, I want to gather sensor data with my Arduino UNO R3 over some period of time. During this interval I want to power my board with an external power source and not through the USB port of my laptop. After the data has been gathered I want to connect the board to my PC to transfer the data via USB. Unfortunately I noticed that when I start the python-script which I wrote for the communication between laptop and the Arduino, the board resets so that the previously gathered data is lost.
So I would like to ask if my approach is wrong, i.e. connecting a running board to the laptop, or if there might be something wrong with my programms. Perhaps it is important to mention that the external power source yields only 5 volts; though I have never experienced any problems with it before.
Maybe there is an entirely better method to transfer information from an Arduino to a PC to which it was formerly not connected.
If there is some information missing to solve the problem, please tell me what is missing and I will try to supply it.
Many thanks in advance for our help!
You can cut a trace on the board to disable the USB enable. You then have to manually press Reset for a code download, not a big deal.
You can store the data gathered, up to 1024 bytes, in the '328Ps EEPROM. Then a reset won't matter. "The Uno board contains a trace that can be cut to disable the auto-reset. The pads on either side of the trace can be soldered together to re-enable it. It's labeled "RESET-EN". You may also be able to disable the auto-reset by connecting a 110 ohm resistor from 5V to the reset line; see this forum thread for details. " Excerpted from this page https://www.arduino.cc/en/Main/ArduinoBoardUno
It is normal for the Arduino to reset when the PC opens the serial port.
One solution is to use a USB-TTL cable connected directly to pins 0 and 1 rather than the normal Arduino USB connector.
...R
More than that, it was how the Arduino was designed to work.
Another way of disabling the auto reset is to attach a 10uF capacitor between the reset pin and ground.
Thank you for your input: this solves my problem. Using the EEPROM seems to be the simplest solution for my purposes.
It is interesting for the future to learn that opening a serial port by default resets the board and how to work around it.
