arduino board resets often
while im working with tft screen
my arduino mega board resets within 10 seconds.
all the values and printed data gone and start freshly.
how can i recover from this ?
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define   BLACK           0x0000
#define   BLUE            0x001F
#define   RED             0xF800
#define   GREEN           0x07E0
#define   CYAN            0x07FF
#define   MAGENTA         0xF81F
#define   YELLOW          0xFFE0
#define   WHITE           0xFFFF
#include "TFTLCD.h"
#include <Keypad.h>
const byte ROWS = 5;
const byte COLS = 4;
char buff[10];
long lastUpdate = 0;
int x,i;
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
char keys[ROWS][COLS] =
  {'1','6','A','D'},
  {'2','7','B','E'},
  {'3','8','C','F'},
  {'4','9','X','Y'},
  {'5','0','Z','R'},
byte rowPins[ROWS] = {40,39,38,37,36}; //connect to row pinouts
byte colPins[COLS] = {32,33,34,35}; //connect to column pinouts
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(void)
  Serial.println("8 Bit LCD test!");
  tft.reset();
  tft.initDisplay();
void loop(void)
  char key = keypad.getKey();
  if (key != NO_KEY)
    buff[i] = key;
    i = i+1;
    x=x+8;
  if((millis() - lastUpdate) > 700)  // has it been >1 second since the last update?
    testtext(BLACK);  // update display
    lastUpdate = millis();
   // remember the time
void testtext(uint16_t color)
  tft.fillScreen(CYAN);
  tft.setCursor(50, 20);
  tft.setTextColor(RED);
  tft.setTextSize(2);
  tft.println("Enter your ");
   tft.setCursor(50, 40);
  tft.println("Student ID");
  tft.setCursor(x, 60);
  tft.setTextSize(2);
  tft.print(buff);
char buff[10];
    buff[i] = key;
    i = i+1;
You've declared buff to have 10 components, but i is never set to anything but its value plus one, so after 10 key presses, you're outside the bounds of your buffer.
yes thats a fact :slight_smile: . i will limit them
but before i implement up to this point already it behaves like this. :frowning:
Can it be that you are drawing more power, than the system can support, so it goes to reset?
What's your power source, how much drawing off it?
jackwp:
Also, make sure you aren't accidently connecting the Vcc (5V) pin to any input pin directly (without a resistor) because this resets the board.
jackwp
my power source is usb from labtop.
ill try on external DC power supply
charredgrass
ive connected Vcc ( 5 v) to tft screen's Vcc without any resister.
and that is the one and only connection im using 5v.
