Arduino Board - wrong connection of analog pin (Arduino 2009)
Hello everyone, I just check my Arduino 2009 (Duemilanove) board with a digital multimeter and I've found that the Analog Pin (A3) is connected to the ground :astonished: any solution for that ? (I need some simple solution without ruining the Arduino looks) Thank you :)
If you pull the '328P chip, is it still shorted? If yes, look for a short on the board, solder bridge or similar. If not, then likely there is something wrong with the chip.
Iblex: Hello everyone, I just check my Arduino 2009 (Duemilanove) board *with a digital multimeter and I've found that the Analog Pin (A3) is connected to the ground * :astonished: any solution for that ? (I need some simple solution without ruining the Arduino looks) Thank you :)
How exactly did you determine you have a shorted pin to ground, what measurements did you take with the multimeter?
Lefty
