Arduino boolean operators
Hello, I am busy writing a GUI class that has toggle buttons. These buttons can be in one of two states, and thus a boolean is used to save their states. I check if the button is pressed, and then toggle the state boolean. When doing this I noticed that using
boolean state = false;
state != state;
Gave me unexpected results, however
state = !state;
Behaves as expected. Below is a simple demo to demonstrate this behavior.
boolean test = false;
  Serial.println(test); //Expected 0 Actual 0
  test != test;
  Serial.println(test); //Expected 1 Actual 0
  test = !test;
  Serial.println(test); //Expected 0 Actual 1
I was just wondering if anyone knows why the first case is not implemented?
state != stateis a comparison, the result of which is ignored.
Obviously... Thank you :-[.
Otherwise the assignment and comparison would be indistinguishable.
Try exclusive or with 1:
test ^= 1;
edgemoron:
test ^= 1
That's not safe for all booleans. A boolean true is a non-zero value, not 1. It can be one but it might not be. If the value is 7 and you do that, you end up with 6 which is still a true. As far as I know, only negation will guarantee the conversion of any non zero value to a zero.
I stand corrected :blush: again.
state != state
The “op=” syntax only works for operations have two operands. After all, “A op= B;” is short for “A = A op B;” The only thing surprising about “A != B;” is that it doesn’t result in an error message, which is just C being C (“it’s just fine that you wrote a statement that doesn’t do anything. I’m sure that’s exactly what you meant to do!”)
Try this easy to read, easy to remember method:
state = not state;
