arduino bootloader error
I have been trying to burn a bootloader to my atmega8 chip.
There are 2 questions
  1. Can I use atmega328 arduuino uno board to burn bootloader to atmega8?
  2. Does the following error make any sense to anyone?
Arduino: 1.6.5 (Windows 7), Board: "Arduino NG or older, ATmega8"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega8 -cstk500v1 -PCOM13 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0xca:m -Ulfuse:w:0xdf:m
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM13
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9307
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Error while burning bootloader.
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
"efuse" memory type not defined for part "ATmega8"
avrdude done. Thank you.
Looks like an IDE bug. The IDE is trying to set the non-existent Extended fuse byte. You could try an older version of the IDE from back in the time when the Arduino NG was more common. I'd try 1.0.6.
Alternatively, you can learn to run avrdude directly. You can grab the commands from the verbose output and strip out the bad part:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.con -v -patmega8 -cstk500v1 -PCOM13 -b19200 -e -Ulock:w:0x3F:m -Uhfuse:w:0xca:m -Ulfuse:w:0xdf:m
... if John is correct (he has a wonderful track record) you could try an older version of the IDE... maybe go back as far as a year since the IDE is constantly being revised as part of a number of efforts.
Ray
This ide bug has been known for a while. Looking at how the hardware spec works for platform.txt and such, I don't see how this could be fixed without creating a separate core that used it's own platform.txt to specify a recipe for calling avrdude without specifying an extended fuse.
Now that separate cores are so much easier to make and install, perhaps that's how the (legacy) ATmega8 cpus should handled?
Thank you :slight_smile:
The GitHub issue for this is Write bootloader - problem on ATmega8 · Issue #2075 · arduino/Arduino · GitHub. IMO the best solution, which only requires an edit of avrdude.conf is described at Write bootloader - problem on ATmega8 · Issue #2075 · arduino/Arduino · GitHub. I have tested it and it works well. It could also be solved by creating a different avrdude tool in Arduino AVR Boards platform.txt(as explained at "efuse" memory type not defined for part "ATMEGA8" · Issue #2541 · arduino/Arduino · GitHub) but that adds a lot of clutter just for a single board so I think the avrdude.conf solution is much better.
Yes, I know this is an old thread but I had it on my issues to report list and just got to it. I've learned more about the issue in the meantime and thought I should update the thread.
I'm surprised that the Arduino team haven't done anything about this, even though this issue have been known for years!
The fix in the avrdude.conf was rather clever! I might incorporate that in MightyCore and MiniCore before the next releases :slight_smile: It's almost like cheating, but much more elegant than having two different avrdude options in the platform.txt file
Yes, I thought of you when I saw that solution because I have noticed your avrdudeCustom tool solution but I figured that your way works just as well so decided not to bring it up.
