Arduino bootloader on Atmel328P TQFP package
Hi All,
Does the TQFP package support the aruino bootloader as well ? I am thinking of replacing the DIP with a TQFP package, while doing so is it any different from the DIP in terms of layout, signal path component placement or anything else that should consider.
cheers.
(deleted)
thanks.
Waht are the different packages for 42pin, 32pin and some more than these. The DIP is just 28pin.
32 pin package has two more analog inputs and more power pins.
Thank you.
