Arduino Bootloader Source - Where is it hiding?
There is a good chance its me, (and it was...)But where can I find the source for the bootloader? I am looking at modifying a bootloader for a different clock rate and I think I have found the byte that needs changing, but I would like to look at some source code to make sure.
It would also let me put useful labels to the code I have disassembled in AVRStudio4.
Thanks -
Okay - I found it on github.
Now - How about the loader source for the Arduino-Tiny collection of bootloaders?
Thanks
in your arduino install directory, there is ...hardware/arduino/bootloaders Some bootloaders have newer versions on github/etc, but the arduino install should be a good starting point.
The what?
Arduino Tiny is an add-on for Arduino that has the description files for some of the Tiny series chips. I found it looking for a way to program the ATtiny2313.
I believe that “Tiny” doesn’t actually use a bootloader. In the 1.0, you program your chips with Shift-upload, which uses an external programmer to do the actual programming. The files in the bootloader directory are called “empty”, and are placeholders to allow fuse burning or something, but I don’t think they’re actual bootloaders (now, if only they LOOKED like empty files!)
