hey guys i have made a 3 ft robot controlled by arduino .what should i make the outer covering of the robot with(body).thanks in adavnce
Depends on your robot. If it is for combat you probably want plate steel. If it doesn't have a lot of spare torque you probably want something light like foamcore. You could use a nylon skin and inflation fan to make it a 20-foot-tall robot.
johnwasser:
thanks .the bot does not need to be strong (combat)and i also want to keep it light so that i uses less energy. should i use foam core . thanks again
manansh:
Yes.
