Arduino Bricked???
I have been using an Arduino Uno in my project. I didn't use it for the past week.
Now when I power it up the LED 13 and Power light is always on (no flashing when powered up).
If I try to upload any code to the board it is showing
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
I googled the error and some said re-burn the bootloader. When I do that I get the same error as above.
When I try to upload the code only the RX LED blinks a few times and my reset button doesn't seem to work. When I press it nothing happens, no blinking LED nothing.
I believe that this is due a problem in the arduino not in the IDE.
Can anyone help me solve this? Thanks in advance.
You need to burn the bootloader. Do you have another arduino ?
NO I don't have another arduino and as I said in the post it is showing an error when I try to burn the bootloader.
You can't burn the bootloader if you don't have a ISP(In System Programmer). Get a ISP or a Atmega328 PRE burnt with the bootloader or another Arduino. You can find UNO on Flipkart for ~~RS.500.(~$10)
