arduino broke again
i bought an arduino a month ago i got an error message so i posted a forum topic about it that can be seen here nothing helped so i sent support@arduino.cc an email i tried what he said but that didn't work so i emailed him back and i haven't heard back so i bought another arduino it worked then it stopped working and i got this error message
Arduino: 1.6.4 (Windows 7), Board: "Arduino Uno"
Sketch uses 8,170 bytes (25%) of program storage space. Maximum is 32,256 bytes.
Global variables use 628 bytes (30%) of dynamic memory, leaving 1,420 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x51
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x51
enabled in File > Preferences.
i just reloaded the firmware for the 8u2 and it still doesn’t work
Enable "Show verbose output during compilation" in File>Preferences.
Do you have the right COM port chosen?
Does the Arduino show up in Device Manager?
Try the loopback test.http://forum.arduino.cc/index.php?topic=73748.0
Isaac96:
  1. Enable "Show verbose output during compilation" in File>Preferences.
  2. Do you have the right COM port chosen?
  3. Does the Arduino show up in Device Manager?
  4. Try the loopback test.Loop-Back Test Instructions - Installation & Troubleshooting - Arduino Forum
  1. ok here is the errorArduino: 1.6.4 (Windows 7), Board: "Arduino Uno"
Using library AccelStepper in folder: C:\Program Files (x86)\Arduino\libraries\AccelStepper (legacy)
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library Adafruit Motor Shield V2 Library in folder: C:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\AccelStepper -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Accel_MultiStepper.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Accel_MultiStepper.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\AccelStepper -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library -IC:\Program Files (x86)\Arduino\libraries\AccelStepper\utility C:\Program Files (x86)\Arduino\libraries\AccelStepper\AccelStepper.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\AccelStepper\AccelStepper.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\AccelStepper -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\Wire.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Wire\Wire.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\AccelStepper -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\utility\twi.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Wire\utility\twi.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\AccelStepper -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library\utility C:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library\Adafruit_MotorShield.cp
 p -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Adafruit Motor Shield V2 Library\Adafruit_MotorShield.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\AccelStepper -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library -IC:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library\utility C:\Users\ben\Documents\Arduino\libraries\Adafruit_Motor_Shield_V2_Library\utility\Adafruit_PWMServoDriver.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Adafruit Motor Shield V2 Library\utility\Adafruit_PWMServoDriver.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\hooks.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\hooks.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\WInterrupts.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_analog.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_analog.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_digital.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_digital.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_pulse.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_shift.c -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_shift.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\abi.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\abi.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\CDC.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\CDC.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial0.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial0.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial1.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial1.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial2.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial2.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial3.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial3.cpp.o
 ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HID.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HID.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\IPAddress.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\IPAddress.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\main.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\main.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\new.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\new.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Print.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Print.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Stream.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Stream.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Tone.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Tone.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\USBCore.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\USBCore.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WMath.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\WMath.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WString.cpp -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\WString.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\hooks.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\WInterrupts.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_analog.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_digital.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_pulse.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\wiring_shift.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\abi.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\CDC.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial0.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial1.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial2.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HardwareSerial3.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\HID.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\IPAddress.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\main.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\new.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Print.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Stream.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Tone.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\USBCore.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\WMath.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\WString.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -w -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/Accel_MultiStepper.cpp.elf C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Accel_MultiStepper.cpp.o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\AccelStepper\AccelStepper.cpp.o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Wire\Wire.cpp.o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Wire\utility\twi.c.o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Adafruit Motor Shield V2 Library\Adafruit_MotorShield.cpp.o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp\Adafruit Motor Shield V2 Library\utility\Adafruit_PWMServoDriver.cpp.o C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/core.a -LC:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp -lm
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/Accel_MultiStepper.cpp.elf C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/Accel_MultiStepper.cpp.eep
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy -O ihex -R .eeprom C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/Accel_MultiStepper.cpp.elf C:\Users\ben\AppData\Local\Temp\build4571428528626398354.tmp/Accel_MultiStepper.cpp.hex
Sketch uses 9,368 bytes (29%) of program storage space. Maximum is 32,256 bytes.
Global variables use 745 bytes (36%) of dynamic memory, leaving 1,303 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa5
  1. yes it shows a check mark next to COM& (arduino uno)
  2. yes it does
  3. nothing echos back
Make sure you have the loopback test correct. Could you post a pic of your setup?
Here it is
Here is the arduino
Well, the loopback test is supposed to be done with nothing connected to the Arduino. Disconnect everything, short RESET to ground, short the RX and TX pins, and try again.
oh sorry i thought you wanted a picture with the stepper motors and the driver in too
i did the loopback test with nothing connected
Well, if the loopback test isn’t working, that means your USB-to-serial chip is broken. Did you try the loopback test with the serial monitor or with something else? If you don’t already have PuTTY, I have attached it.
PuTTY.zip (259 KB)
yes i used the serial monitor that is in the ide under "tools"
what does PuTTY do?
Just ignore it. It was in case you didn't have a terminal application(stupid mistake)
If the port is showing up but it is not echoing anything back, again, make sure you have the right port chosen, and maybe temporarily remove the ATMega. Try it again.
this is my first arduino project so sorry i don't know what you mean by ATMega
Atmega328P-PU (aka ATMega, aka '328P) is the 28-pin chip on the board.
my arduino is an smd
i have another non smd arduino but i would rather use the smd because it is glued on to my project
(don't worry i put some rubber between the arduino and the metal)
has anyone looked into this???
