hi, i'm trying to create a connection between arduino BT and flash using the serialproxy xml socket. i am working on window XP. i uploaded the code to Arduino BT and test it use serial monitor, it is working. when i connect up with flash(use FlashConversation example), the serialproxy show that "failed to open comm port-connection refused". ((when i test it with Arduino-usb all the thing are working well)) :'(
//this is my serialproxy.cfg code:
Config file for serproxy
See serproxy's README file for documentation
Transform newlines coming from the serial port into nils
true (e.g. if using Flash) or false
newlines_to_nils=true
Comm ports used
comm_ports=1,2,3,4,5,6
Default settings
comm_baud=115200 comm_databits=8 comm_stopbits=1 comm_parity=none
Idle time out in seconds
timeout=300
Port 1 settings (ttyS0)
net_port1=5331
Port 2 settings (ttyS1)
net_port2=5332
Port 3 settings (ttyS2)
net_port3=5333
Port 4 settings (ttyS3)
net_port4=5334
Port 5 settings (ttyS4)
net_port5=5335
Port 6 settings (ttyS5)
net_port6=5336
-----my Arduino BT use bluetooth serial com4-------
//output of the flash :: ::) ** Arduino ** Connecting to 127.0.0.1:5334 . . . ** Arduino ** Connection established.
//flash movie show that : :P ** Arduino connected! **
- Flash: Hi Arduino, can you hear me? ** Arduino disconnected! **
--pl help me solve the problem, Thanks :-[
