arduino bt help
hello, everyone. I am new to this forum and to arduino. i was looking for some guidance and help as i am a newbie to this all. What i have is a arduino BT board and 2xLM national temperature sensors that read are designed to read in Fahrenheit. i have an example code for the arduino i have uploaded and am able to stream data, but the data i am getting is obviously wrong. I would like to correct the program to print in F and time stamp each reading. Thank you in advance. I will post the program in a separate post.
// Define which analog input pin we have connected to the temperature sensor
#define TEMP_SENSOR_PIN 0
// if you tie the Arduino's vRef to the 3.3 volt supply, change this to 3.3
#define ANALOG_VOTLAGE_REFERENCE 5
// prints the currrent temperature with 1 place after the decimal point
printFloat(getTemperature(), 1);
// print a carriage return
// rest 100 milliseconds
delay(100);
float CtoF(float c) {
// optionally convert from Celsius to Farenheit if you are into that sorta thing
return c * 9.0 / 5.0 + 32.0;
float analogInToDegreesC(int inputValue) {
// divide by 1023, the maximum possible input value, that scales the input between 0 - 1
// then multiply by the reference voltage, which scales 0-1 to 0-vREF (default is 5V)
// lastly, multiply by 100 to scale it to 10s of millivolts or degrees
return inputValue / 1023.0 * ANALOG_VOTLAGE_REFERENCE * 100.0;
float getTemperature() {
// read the analog input, convert to degrees C, and covert to F
return CtoF(analogInToDegreesC(analogRead(TEMP_SENSOR_PIN)));
// ---- This last function, printFloat isn't necessary to understand unless you want to
// ---- feel free to ignore it for now, and treat it as a built-in utility,
// ---- it prints out floating point point values
// printFloat prints out the float 'value' rounded to 'places' places after the decimal point
void printFloat(float value, int places) {
// this is used to cast digits
int digit;
float tens = 0.1;
int tenscount = 0;
int i;
float tempfloat = value;
// make sure we round properly. this could use pow from <math.h>, but doesn't seem worth the import
// if this rounding step isn't here, the value 54.321 prints as 54.3209
// calculate rounding term d: 0.5/pow(10,places)
float d = 0.5;
if (value < 0)
d *= -1.0;
// divide by ten for each decimal place
for (i = 0; i < places; i++)
d/= 10.0;
// this small addition, combined with truncation will round our values properly
tempfloat += d;
// first get value tens to be the large power of ten less than value
// tenscount isn't necessary but it would be useful if you wanted to know after this how many chars the number will take
ok i have the conversion figured out. Now using the same program i would like to add one more temp sensor on another analog in. i am not sure how to manipulate the code
