Arduino BT + SuperWaba
Hello everybody!
I'm trying to connect an Arduino BT board to a SuperWaba app on a PocketPc. Everything seems to work fine: I can see the BT connection in the BT connections list in XP.
The problem comes when I try to send data (from the SW to ABT). The SW app consists of a group of buttons. I pretend to send some integers to the board everytime that a button is pressed. Seeing that it does not work, I've simplified it so all the buttons do the same task: send a 0 to the board. If the board receives data it is supposed to change the state of a LED (if turned on -> turns it off; if turned off -> turns it on).
The fact is that the board is receiving data, cause some times the LED changes. The main problem is that it NOT always happens. And I haven't noticed a pattern.
Does anybody know why can this be happening? Anything about problems between different protocol (SW - ABT) communications? Anything related to reliability of the BT communications in Arduino (I suppose it has to be reliable...)?
Here's the Arduino code:
int redPin = 11;
int op=-2;
int X=0;
pinMode(redPin, OUTPUT);
long time = millis();
randomSeed(time);
// Reset the bluetooth interface
digitalWrite(RESET, HIGH);
delay(10);
digitalWrite(RESET, LOW);
delay(2000);
//configure the bluetooth module
Serial.println("SET BT PAGEMODE 3 2000 1");
Serial.println("SET BT NAME BTLAMP");
Serial.println("SET BT ROLE 0 f 7d00");
Serial.println("SET CONTROL ECHO 0");
Serial.println("SET BT AUTH * 12345");
Serial.println("SET CONTROL ESCAPE - 00 1");
void loop () {
Serial.flush();
op=Serial.read();
if (op!=-1) {
if(X==255) X=0;
else X=255;
analogWrite(11, X);
Thanks in advance!!!
