Arduino BT uploading problem...
Hello! i just recently bought myself an Arduino BT. I installed my BT adapter on PC, successfully set up virtual COM port and all that. Downloaded the 1.0.1 IDE, chose Arduino BT with ATmega 328 and COM port in tools and then, when I tried to upload an example sketch I got this:
avrdude: writing flash (1084 bytes):
Writing | avrdude: Send: U [55] . [00] . [00]? [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] a [61] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] . [9d] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [00] . [00] . [00] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] . [00] . [00] % [25] . [00] ( [28] . [00] + [2 . [00] . [00] . [00] . [00] . [00]? [20]
avrdude: Recv:
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
avrdude: Send: V [56] @ [40] . [00] . [00] . [0c]? [20]
avrdude: Recv:
avrdude: stk500_cmd(): programmer is out of sync
As I understand this it starts to write flash but then suddenly just stops... I read a lot of topics concerning Arduino BT connection problems but no solution seems to be working for me as of now (did not try bootloader re-write... but not even sure if this is the problem...) Could somebody point me in some direction what can be the cause of this? Is it the Arduino or my bt adapter/drivers?
I run Windows 7 64-bit and 1.0.1 IDE (with pde.jar from 1.0.1-rc2 switch)
UPDATE
on different machine (but still the same BT adapter) managed to upload 3 pages before getting the "programmer out of sync" error, but only once... every other time it goes the same way as above.
