I'm actually on a project with the arduino BT and a Polar bluetooth.
I would like to receive the data sent by the transmitter Bluetooth and use it with de arduino BT.
I found on internet that the protocol of the polar bluetooth must be something like that :
fe 08 f7 02 d1 4b 03 2c
The BPM seems to be 4b for this example.
But I don't know how to receive this packet from the transmitter.
The transmitter always send data, so is it possible to always receive this data when I put the arduino BT ON ? And how can I initiate a communication between this 2 devices.
The Arduino BT supports AFAIK "only" the bluetooth serial profile. If the Polar device is using any other profile you might not have success with the Arduino. The easiest way to test that is by pairing it with your notebook. If you get a new serial device there (COM port for the windows world) it's probably using the serial profile and it worth investing more time to get your Arduino listen to the heart monitor.
Probably not. Bluetooth module X is not equal bluetooth module Y. The module on the referred page is a eUnistone 31308/2, on the Arduino BT is a Bluegiga WT11. That chip comes with different firmwares and unfortunately the hardware page of the Arduino BT (http://arduino.cc/en/Main/ArduinoBoardBluetooth) does not specify which version they use. I don't have the hardware so I cannot try myself (because of the rather inconvenient handling the Arduino BT is not used very often). The best link I found is this: http://www.glynstore.com/content/docs/bluegiga/iWRAP3_User_Guide.pdf
Try it with your board. First you have to establish a serial connection to your PC using SoftwareSerial, use a simple forwarding sketch to send your commands to the bluetooth module and try the commands in the user guide.
I find in the user guide the escape sequence to enter in command mode :
The escape sequence:
The escape sequence causes the iWRAP firmware to go to the command mode from the
data mode or vice versa. The escape sequence consists of three (3) escape characters that
are defined by SET CONTROL ESCAPE command. By default the escape character is ‘+’.
Do not enter any character before and/or after the escape sequence for a guard time
which is 1 second. Also send the escape characters individually, not as a string.
With default settings the escape sequence is:
< 1 second sleep> +++ < 1 second sleep>
When a successful state transition from data mode to command mode is made, iWRAP
sends a “READY.” event to indicate that it’s ready to receive commands.
The same escape sequence or the SELECT command can be used to return to data mode.
As I wrote before, I'd try to do that interactively. That means using a TTL serial like the USB2Serial Light adapter or a FTDI cable to establish a serial command channel from the PC to a SoftwareSerial instance. If you forward everything between this instance and the Serial (going to the BT module) transparently you'll be able to reconfigure the module with your serial terminal. Changing your sketch and uploading it constantly is a tedious and error prone way of exploring the capabilities of your hardware.
Ok I succeeded. I save the result on EEPROM then i display it after.
I am able to PAIR my arduino with my sensor and call it. When I do LIST after my call I can see 1 connection
Now i’m focusing on how retrieve informations send by the sensor, because i’m just connected right now.
Here is my code for now
#include <EEPROM.h>
char inByte = 0; // incoming serial byte
int infoSize = 0 ;
char c;
void setup(){ // run once, when the sketch starts
Serial.begin(115200); // start serial at 115200 kbs
Serial.println("SET CONTROL ESCAPE 43 00 0"); // set control escape 43->+ 00->bit mask 0->DTR disable
void loop(){
// if we get a valid byte, read analog ins:
if (Serial.available() > 0){
inByte = getbyte(); // get incoming byte
if (inByte == '1' ){ // look for a 1
Serial.println("Starting...");
infoSize = getInfo();
Serial.println("Done");
}else if (inByte == '0' ){ // look for a 0
Serial.print("Get string: ");
for(int i=0;i<infoSize;i++){
c=EEPROM.read(i);
Serial.print(c);
Serial.print("Cleared string size: ");
Serial.println(infoSize);
int getInfo(){
int j=0;
//Entering in command mode
delay(2000);
Serial.print("+++");
delay(2000);
Serial.println("SET BT AUTH *"); //no pin code to pair with polar
Serial.println("PAIR 00:22:d0:00:85:87");
delay(4000);
Serial.println("CALL 00:22:d0:00:85:87 1101 RFCOMM");
Serial.println("LIST");
for (int i=0; i <= 10; i++){
while (Serial.available() > 0 && j <512) {
EEPROM.write(j, inByte);
j++;
//Exiting command mode
delay(2000);
delay(2000);
return j;
char getbyte(){
while (Serial.available() == 0){ //look for aviable data
// do nothing, wait for incoming data
return Serial.read(); //return data if available
READY.
LIST 1
LIST 0 CONNECTED RFCOMM 1007 0 0 17 8d 5 e0:b9:a5:2f:57:18 1 IN
When I do my CALL now I can see a RING event incoming.
I guess it's good because the sensor is trying to connect with the arduino but I don't know how to able it to send me data :cold_sweat:
I have also 1 error now...
Get string:
READY.
PAIR 00:22:d0:00:85:87 OK
CALL 1
LIST 1
LIST 0 CONNECTED RFCOMM 1007 0 0 20 8d 5 e0:b9:a5:2f:57:18 1 IN NO CARRIER 1 ERROR 403 RFC_CONNECTION_REJ_SECURITY
UIRY 00:22*RING 0 52:fa:04:76:00:02 1 RFCOMM*
NO CARRIER 0 ERROR 0
Cleared string size: 168
Check what BT version your module uses - isn’t it BT2.0? And I think Polar is using BT4.0 (AKA BT Low Energy or BT Smart). You might need to buy a BT4.0 compatible module.
