So I got the arduino BT and hooked it up to a gyroscope and I was able to upload a sample code to the board and get it running. But, after a few seconds the it stopped working. I looked and the serial port is not being recognized by the ide even after restarting and changing bluetooth dongles. Also, for some strange apparent reason the arduino alpha ide does not allow me to type into it ( windows 7 64 bit) I've tried overwritting the files and deleting and reraring it. Anyone have any idea for a solution to these two problems?
only thing i changed was Serial.begin(9600); to Serial.begin(115200); cause thats what the module was set to work on for the baud.
Sample code below:
/* L3G4200D 3-axis gyro example code
by: Jim Lindblom
SparkFun Electronics
date: 4/18/11
license: CC-SA 3.0 - Use this code however you'd like, all we ask
for is attribution. And let us know if you've improved anything!
Circuit:
L3G4200D Breakout-------------Arduino Uno
GND-----------------------------GND
VCC-----------------------------3.3V
SCL-----------------------------D13
SDA-----------------------------D11
SDO-----------------------------D12
CS------------------------------D10
INT2----------------------------D6
INT1----------------------------D7
This example code is intended for use with ST. Microelectronics'
L3G4200D triple-axis digital gyroscop. The L3G4200D is capable of
both I2C and SPI communications, but we'll use SPI in this example.
This code sets up the L3G4200D's 5 control registers, and then
streams the data from all three axes over the Serial Monitor at 9600bps.
#include <SPI.h>
#include "L3G4200D.h"
// pin definitions
const int int2pin = 6;
const int int1pin = 7;
const int chipSelect = 10;
// gyro readings
int x, y, z;
// Start the SPI library:
SPI.begin();
SPI.setDataMode(SPI_MODE3);
SPI.setClockDivider(SPI_CLOCK_DIV8);
pinMode(int1pin, INPUT);
pinMode(int2pin, INPUT);
pinMode(chipSelect, OUTPUT);
digitalWrite(chipSelect, HIGH);
delay(100);
setupL3G4200D(2); // Configure L3G4200 with selectabe full scale range
// 0: 250 dps
// 1: 500 dps
// 2: 2000 dps
// Don't read gyro values until the gyro says it's ready
while(!digitalRead(int2pin))
getGyroValues(); // This will update x, y, and z with new values
Serial.print(x, DEC);
Serial.print("\t");
Serial.print(y, DEC);
Serial.print("\t");
Serial.print(z, DEC);
Serial.print("\t");
//delay(100); // may want to stick this in for readability
int readRegister(byte address)
int toRead;
address |= 0x80; // This tells the L3G4200D we're reading;
digitalWrite(chipSelect, LOW);
SPI.transfer(address);
toRead = SPI.transfer(0x00);
return toRead;
void writeRegister(byte address, byte data)
address &= 0x7F; // This to tell the L3G4200D we're writing
SPI.transfer(data);
int setupL3G4200D(byte fullScale)
// Let's first check that we're communicating properly
// The WHO_AM_I register should read 0xD3
if(readRegister(WHO_AM_I)!=0xD3)
return -1;
// Enable x, y, z and turn off power down:
writeRegister(CTRL_REG1, 0b00001111);
// If you'd like to adjust/use the HPF, you can edit the line below to configure CTRL_REG2:
writeRegister(CTRL_REG2, 0b00000000);
// Configure CTRL_REG3 to generate data ready interrupt on INT2
// No interrupts used on INT1, if you'd like to configure INT1
// or INT2 otherwise, consult the datasheet:
writeRegister(CTRL_REG3, 0b00001000);
// CTRL_REG4 controls the full-scale range, among other things:
fullScale &= 0x03;
writeRegister(CTRL_REG4, fullScale<<4);
// CTRL_REG5 controls high-pass filtering of outputs, use it
// if you'd like:
writeRegister(CTRL_REG5, 0b00000000);
void getGyroValues()
x = (readRegister(0x29)&0xFF)<<8;
x |= (readRegister(0x28)&0xFF);
y = (readRegister(0x2B)&0xFF)<<8;
y |= (readRegister(0x2A)&0xFF);
z = (readRegister(0x2D)&0xFF)<<8;
z |= (readRegister(0x2C)&0xFF);
