In order for the script work as it is supposed to you need to set few variables (full path to arduino ide, what extra libraries you need, which COM port arduino can be seen).
Script can compile the project in C/C++ (you need to include #include"WProgram.h" in header files).
As far as pde files go, they can be compiled as well. All you need to remember is at the beginning of the main file (the one named exactly as the project catalog is) you need to add function prototypes. Normally, when compiling it is the ArduinIDE to generate and add prototypes into a file. However, writing a parser in bat that would be doing this is one of those "mission impossible" things to achieve. So, you are better off adding it yourself. In general, ArduinoIDE compiles pde files just like C++ files. When there are few of them it gets them glued at the end of the main file, adding prototypes and #inlude "WProgram.h" at the beginning.
Whole process is described here http://www.arduino.cc/en/Hacking/BuildProcess
I'm not sure if this script will perform well if there are spaces in path names, though :-/
make.bat
@echo off
echo.
echo Simple Arduino make script.
echo.
echo Author: Adrian Brzezinski
echo Contact: adrb@wp.pl iz0@poczta.onet.pl
echo.
set arduino_sketch_path=D:\arduino\sources\ecucom
set arduino_external_libs=ks0108 Wire Wire\utility
set arduino_ide_path=D:\programs\ArduinoIDE
set arduino_ide_version=18
set arduino_core_path=%arduino_ide_path%\hardware\arduino\cores\arduino
set avr_includes= -I%arduino_ide_path%\hardware\tools\avr\avr\include\avr -I%arduino_core_path% -I%arduino_sketch_path%
set avr_mcu=atmega328p
set avr_f_cpu=16000000L
set avr_flash_size=30720
set avr_sram_size=2048
set avr_bin_path=%arduino_ide_path%\hardware\tools\avr\bin
set avr_etc_path=%arduino_ide_path%\hardware\tools\avr\etc
set avr_gcc=%avr_bin_path%\avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=%avr_mcu% -DF_CPU=%avr_f_cpu% -DARDUINO=%arduino_ide_version%
set avr_g++=%avr_bin_path%\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=%avr_mcu% -DF_CPU=%avr_f_cpu% -DARDUINO=%arduino_ide_version%
set avr_out_path=.\build
set avrdude_port=COM2
set avrdude_protocol=stk500v1
set avrdude_speed=57600
setlocal EnableExtensions
setlocal EnableDelayedExpansion
echo Cleaning up...
rd /s /q %avr_out_path% 2>nul
md %avr_out_path%
echo.
echo Building core.
echo.
for %%s in (%arduino_core_path%\*.c %arduino_core_path%\*.cpp) do (
echo Compiling file %%~nxs
if %%~xs == .c (
%avr_gcc% -I%arduino_core_path% %%s -o%avr_out_path%\%%~nxs.o
if %%~xs == .cpp (
%avr_g++% -I%arduino_core_path% %%s -o%avr_out_path%\%%~nxs.o
echo.
echo Building selected external libs.
echo ( %arduino_external_libs% )
echo.
set arduino_extlib_inc=
for %%l in (%arduino_external_libs%) do (
set arduino_extlib_inc=!arduino_extlib_inc! -I%arduino_ide_path%\libraries\%%l
set arduino_extlib_path=%arduino_ide_path%\libraries\%%l
for /f "tokens=*" %%s in ('dir /s /b !arduino_extlib_path!\*.c !arduino_extlib_path!\*.cpp') do (
if not exist "%avr_out_path%\%%~nxs.o" (
if %%~xs == .c (
%avr_gcc% %avr_includes% %arduino_extlib_inc% %%s -o%avr_out_path%\%%~nxs.o
if %%~xs == .cpp (
%avr_g++% %avr_includes% %arduino_extlib_inc% %%s -o%avr_out_path%\%%~nxs.o
REM Retriving sketch name from path
set _app=%arduino_sketch_path%
:nexchar
set _t=%_app:~-1%
set _app=%_app:~0,-1%
if %_t% == \ goto :setsketchname
if %_t% == / goto :setsketchname
goto :nexchar
:setsketchname
set arduino_sketch_name=!arduino_sketch_path:%_app%\=!
echo.
echo Building sketch.
echo ( %arduino_sketch_name% )
echo.
if exist %arduino_sketch_path%\%arduino_sketch_name%.pde (
echo Processing file %arduino_sketch_name%.pde
echo #include "WProgram.h" >> %avr_out_path%\%arduino_sketch_name%.cpp
type %arduino_sketch_path%\%arduino_sketch_name%.pde >> %avr_out_path%\%arduino_sketch_name%.cpp
for %%s in (%arduino_sketch_path%\*.pde %arduino_sketch_path%\*.c %arduino_sketch_path%\*.cpp) do (
if %%~xs == .pde (
if not %%~nxs == %arduino_sketch_name%.pde (
echo Processing file %%~nxs
type %%s >> %avr_out_path%\%arduino_sketch_name%.cpp
) else (
if %%~xs == .c (
if %%~xs == .cpp (
if exist %avr_out_path%\%arduino_sketch_name%.cpp (
echo.
echo Compiling pde files
%avr_g++% %avr_includes% %arduino_extlib_inc% %avr_out_path%\%arduino_sketch_name%.cpp -o%avr_out_path%\%arduino_sketch_name%.o
echo.
echo Linking all
echo.
%avr_bin_path%\avr-ar rcs %avr_out_path%\%arduino_sketch_name%.a %avr_out_path%\*.o
%avr_bin_path%\avr-gcc -Os -Wl,--gc-sections -mmcu=%avr_mcu% -o %avr_out_path%\%arduino_sketch_name%.elf %avr_out_path%\%arduino_sketch_name%.a -L%avr_out_path% -lm
%avr_bin_path%\avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 %avr_out_path%\%arduino_sketch_name%.elf %avr_out_path%\%arduino_sketch_name%.eep
%avr_bin_path%\avr-objcopy -O ihex -R .eeprom %avr_out_path%\%arduino_sketch_name%.elf %avr_out_path%\%arduino_sketch_name%.hex
set /a hex_size=0
set /a elf_sram=0
if exist %avr_out_path%\%arduino_sketch_name%.hex (
for /f "skip=3 tokens=1-3" %%a in ('%avr_bin_path%\avr-size -A %avr_out_path%\%arduino_sketch_name%.hex') do set /a hex_size=%%b
echo Binary sketch size: !hex_size! bytes, of a %avr_flash_size% byte maximum.
for /f "skip=2 tokens=1-3" %%a in ('%avr_bin_path%\avr-size -A %avr_out_path%\%arduino_sketch_name%.elf') do (
if %%a == .data (
set /a elf_sram+=%%b
if %%a == .bss (
echo Static memory usage: !elf_sram! bytes, of a %avr_sram_size% byte maximum.
if !elf_sram! geq %avr_sram_size% echo WARNING! Oversized SRAM!
if !hex_size! leq %avr_flash_size% (
echo.
set /p upload=Upload sketch [y/n]?
if !upload! == y (
%avr_bin_path%\avrdude -C%avr_etc_path%\avrdude.conf -p%avr_mcu% -c%avrdude_protocol% -P\\.\%avrdude_port% -b%avrdude_speed% -D -u -V -Uflash:w:"%avr_out_path%\%arduino_sketch_name%.hex":i
) else (
echo WARNING! Oversized sketch file!
echo All done.
pause
