Arduino button box for iRacing - control only responding intermittently
Hi All
Pretty new to Arduino, and building myself a button box for iRacing.
I’m using a rotary encoder to (try to) control ABS, TCS and brake bias. My challenge is that it only intermittently increments/decrements the selected control, rather than with each detente.
I have tested the setup on other software (FSX) and each detente sends the command and the sim responds, but in iRacing it only seems to respond randomly
Basically, it has 3 switch modes (toggled with the pushbutton switch of the encoder), and depending on the switch mode when the interrupt procedure is called, it sends a different set of key presses.
the interrupt procedure code is below:
Procedure is called with:
attachInterrupt(0, adjustRE, CHANGE);
And the actual procedure is:
void adjustRE(){
     if(digitalRead(3) == digitalRead(2)){
        if(switchVal==1){
          Keyboard.press(KEY_LEFT_CTRL);
          Keyboard.press(KEY_LEFT_SHIFT);
          Keyboard.press('u');
          delay(100);
          Keyboard.release('u');
          Keyboard.releaseAll();
        if (switchVal==2){
          Serial.println("2 +");
          Keyboard.press(KEY_LEFT_ALT);
          delay(100);
       if (switchVal==3){
          delay(100);
   else {
        if(switchVal==1){
          Keyboard.press('b');
          delay(100);
          Keyboard.release('b');
        if (switchVal==2){
          delay(100);
       if (switchVal==3){
          delay(100);
Any thoughts/help would be greatly appreciated!
I’ve also attached the full sketch…
THanks
Button_Box_rev_b.ino (7.96 KB)
Does the Keyboard library use interrupts ? delay() does, and as interrupts are disabled when in an ISR this could cause a problem.
