Hi all, i'm student, and still progress do my project for my task exam. I hope kindly anyone can help me because i'm still beginner for programming.
I build project about smarthome arduino can control with telegram and i use python programming for connection from arduino to telegram.
and i want ask about read component (pushbutton) from python to telegram :
If pushbutton pressed the lamp is turn ON, arduino will send the information to python and telegram that "pushbutton pressed, and the lamp turn ON"
python :
#!/usr/bin/python
import telepot, time, serial
ser = serial.Serial('COM10', 9600, timeout=1)
def handle(msg):
userName = msg['from']['first_name']+" "+msg['from']['last_name']
content_type, chat_type, chat_id = telepot.glance2(msg)
buffer=ser.read()
if (content_type == 'text'):
command = msg['text']
print ('Got command: %s' % command)
if '/hello' in command:
bot.sendMessage(chat_id, "Assalamu'alaikum "+userName+", ..?")
if '/lampu1_1' in command:
ser.write(b'A')
bot.sendMessage(chat_id, "Lampu1 ON")
if '/lampu1_0' in command:
ser.write(b'B')
bot.sendMessage(chat_id, "Lampu1 OFF")
if '/lampu2_1' in command:
ser.write(b'C')
bot.sendMessage(chat_id, "Lampu2 ON")
if '/lampu2_0' in command:
ser.write(b'D')
bot.sendMessage(chat_id, "Lampu2 OFF")
elif(content_type == 'text'):
print ('Got command: %s' %command)
if buffer=="H" :
bot.sendMessage(chat_id, "pushbutton pressed, the lamp turn ON")
if buffer=="M" :
bot.sendMessage(chat_id, "pushbutton unpress, the lamp turn OFF")
# Create a bot using the token given by BotFather
bot = telepot.Bot('201023475:AAF_Ym_l662EayJpG8hWG-rMMQKbETW_4Yw')
# Add handle function to be called every received message.
bot.notifyOnMessage(handle)
#bot.notifyOnMessage(tekan)
# Wait for new messages
while 1:
time.sleep(20)
and script for pushbutton *python :
if buffer=="H" :
if buffer=="M" :
Arduino Code :
const int ledPin = 12; // the pin that the LED is attached to
unsigned int incomingByte; // a variable to read incoming serial data into
int button=10;
int val=0;
unsigned int outgoingByte;
int LED_state=LOW;
// initialize serial communication:
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
pinMode(button, INPUT);
if(digitalRead(button)==LOW)
if(LED_state==LOW){
digitalWrite(ledPin,LOW);
LED_state=HIGH;
Serial.write("H");
else{
digitalWrite(ledPin,HIGH);
LED_state=LOW;
Serial.write("M");
delay(300);
// read the oldest byte in the serial buffer:
incomingByte = Serial.read();
// if it's a capital H (ASCII 72), turn on the LED:
if (incomingByte == 'D') {
digitalWrite(ledPin, LOW);
Serial.print("Lampu Mati");
Serial.print("\n");
// if it's an L (ASCII 76) turn off the LED:
else if (incomingByte == 'C') {
digitalWrite(ledPin, HIGH);
Serial.print("Lampu Hidup");
Serial.print("\n");
code pushbutton in arduino code :
if(LED_state==LOW){
LED_state=HIGH;
Serial.write("H");
else{
LED_state=LOW;
Serial.write("M");
delay(300);
I hope anyone can help me, please
the problem : Pushbutton if pressed can't work send message to telegram
I already try use seral monitor in arduino, pushbutton working and the lamp is turn on and show the command in serial monitor in arduino
But with telegram can't work
