Arduino Button with Yellow Jacket Planetary Gear Motor
Hello, I am doing a project with an Arduino and a gobilda motor, I am wanting to use a button to start the motor and when I press it again, it will stop the motor. Well what happens is that when you connect the battery to the motor it automatically starts the motor, also when you press the button what it does is make the movement rotate to the opposite side when what I want to do is start it when you click.
Motor: 5203 Series Yellow Jacket Planetary Gear Motor (50.9:1 Ratio, 24mm Length 8mm REX™ Shaft, 117 RPM, 3.3 - 5V Encoder) - goBILDA®
Diagram Wiring : https://www.gobilda.com/content/videos/m1/wiring_diagram.pdf
#include <Servo.h>
Servo esc_1;
int botonPin = 2;
int estadoBoton = 0;
int ultimoEstadoBoton = HIGH;
bool motorEncendido = false;
unsigned long tiempoUltimoCambio = 0;
unsigned long debounceDelay = 200;
  esc_1.attach(9);
  pinMode(botonPin, INPUT_PULLUP);
  set_esc_power(esc_1, 0);
  Serial.println("Sistema iniciado");
  int lecturaBoton = digitalRead(botonPin);
  // Comprobar si ha pasado el tiempo de debounce
  if (lecturaBoton != ultimoEstadoBoton) {
    tiempoUltimoCambio = millis();
  // Solo actuamos si ha pasado suficiente tiempo desde el último cambio
  if ((millis() - tiempoUltimoCambio) > debounceDelay) {
    // Si el botón se presionó (transición de HIGH a LOW)
    if (lecturaBoton == LOW && ultimoEstadoBoton == HIGH) {
      motorEncendido = !motorEncendido;
      if (motorEncendido) {
        set_esc_power(esc_1, 100);
        Serial.println("Motor encendido");
        Serial.println("Motor apagado");
      delay(50);
  ultimoEstadoBoton = lecturaBoton;
void set_esc_power(Servo esc, int power) {
  power = constrain(power, 0, 100);
  int signal_min = 1050;
  int signal_max = 1950;
  int signal_output = map(power, 0, 100, signal_min, signal_max);
  esc.writeMicroseconds(signal_output);  // Enviar la señal al ESC
Welcome to the Arduino forum. Giving a link to a schematic/wiring diagram doe not help at all because the problem is with YOUR own wiring. Please show a drawing of how your actually have the wiring.
Your drawing does not show a button. You probably wired the button incorrectly.
Disconnect the Arduino.
Connect only the battery, controller and motor.
What do you observe?
