Arduino buttons not working
I used 3 buttons to do test, the first button not work, I mean when pressed button1, no response, there is a sound when pressed the button2 and button3. Why?
The buttons wired at A0/A1/A2, and the Piezoelectric Ceramics wired at pin9 and gnd.
Thanks
int speaker = 9;
int frequency = 2800; //
const int testing_button = A0;
const int melody_button = A1;      //melody
const int testing_a_button = A2;    //Mosquitoes, Fleas, House Fly, Spiders, Cockroaches
boolean pressed = false;
  Serial.println("setup"); // Prints "Setup to the serial monitor"
  pinMode(testing_button, INPUT_PULLUP);
  pinMode(melody_button, INPUT_PULLUP);
  pinMode(testing_a_button, INPUT_PULLUP);
  pinMode(speaker, OUTPUT);
  digitalWrite(testing_button, HIGH);
  digitalWrite(melody_button, HIGH);
  digitalWrite(testing_a_button, HIGH);
  int buttonState0 = digitalRead(testing_button);
  if (buttonState0 == LOW) {
    tone(speaker, frequency, 1000); // f=3100
    pressed = true;
  int buttonState1 = digitalRead(melody_button);
  if (buttonState1 == LOW) {
    pressed = true;
  int buttonState2 = digitalRead(testing_a_button);
  if (buttonState2 == LOW) {
    delay(5);
    pressed = true;
  if (pressed) {
    digitalWrite(13, true);      // Flash a light to show transmitting
    //  vw_send((uint8_t *)msg, strlen(msg)); //Sending the message
    // vw_wait_tx(); // Wait until the whole message is gone
    //    Serial.println(*msg);
    digitalWrite(13, false);   // Turn the LED off.
    delay(5);
Show your schematic.
if (pressed) {
    delay(5);
You only flash your light for a few hundred nanoseconds. Nobody is going to see that.
Delta_G:
if (pressed) {
    delay(5);
Thanks
Actually I disabled the flashing.
I have a long tone of : tone(speaker, frequency, 1000); // f=3100 for each button, only the first button doesn't work, even shift the 1/2 as 2/1 still the first button no work.
larryd:
Delta_G:
Sorry, I am trying to open my PROTEUS but failed.
laoadam:
You can just draw it, you know with a pencil and paper like we did in the old days. Sometimes that's easier. And we'd definitely prefer that to something like Fritzing. Whatever you do, make it accurate. Don't put things in wrong just because whatever you're using doesn't have the parts you used.
