Hello, I've been making a project to send orders and read information to and from Arduino using a webpage made in PHP (locally hosted in Apache). Since Serial Port Reading from PHP in Windows is impossible (without paying like 30 dollars) I made 3 C++ programs to open a COM Port (The one that the Arduino is assigned to) send/read and send-read data from it. The problem I have is actually trivial or unimportant, but annoying. If for some reason I decide to open the Serial Monitor and then close it (Let's say, I make a demonstration of how to send and read using the Serial Port without making an external program) If I call any of the aforementioned programs again to write or read (or both) on the Arduino, the board will simply deny itself to either carry out the corresponding orders (powering up a LED for example) or send anything to the Serial Port (The temperature value read by an LM35 as an example). I'm using Arduino UNO R3.
This is what my "WriteSerial" program should print in the command prompt whenever it works:
WriteSerial COM3 0 /*The 0 argument powers up the LED */
GetCommState: OK
SetCommState: OK
SetCommTimeouts: OK
WriteFile: 0
WriteSerial COM3 1 /*The 1 argument powers it down */
GetCommState: OK
SetCommState: OK
SetCommTimeouts: OK
WriteFile: 1
GetCommState: OK
If I open the Serial Monitor and then close it, the program still prints the above, but the Arduino won't turn on or off the LED, however all 3 states are still shown as OK.
It can be ""solved" by unplugging the Arduino (and therefore powering it down) and plugging it again.
This is the WriteSerial code (In C++):
#include <stdio.h>
#include <stdlib.h>
#include <windows.h>
HANDLE hSerial;
char serialPort[22];
char szBuff[99];
HANDLE port_open(char serialPort[])
/* Abrir un archivo con los siguientes parametros:
Nombre: serialPort;
Accesso solicitado: Lectura y escritura;
Compartir: No compartir;
Medidas de seguirdad: Nulas;
Disposicion de creacion: Abrir archivo existente;
Atributos del archivo: Sin atributos / Estándar */
hSerial = CreateFile(serialPort, GENERIC_READ | GENERIC_WRITE,
0, 0, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL,0);
/* Manija al archivo: 'hSerial' */
if(hSerial!=INVALID_HANDLE_VALUE)
DCB dcbSerialParams = {0}; /*Crear una estructura de tipo DCB de identificador dcbSerialParams */
DCB dcbSerial = {0};
dcbSerial.DCBlength=sizeof(dcbSerialParams);
if (!GetCommState(hSerial, &dcbSerialParams)) /* Solicitar estado de comunicacion del puerto indicado por hSerial con su configuracion de controles dada por dcbSerialParams */
printf("\nError de GetCommState!");
printf("\nFase GetCommState: OK.");
dcbSerialParams.BaudRate=CBR_9600;
dcbSerialParams.ByteSize=8;
dcbSerialParams.StopBits=ONESTOPBIT;
dcbSerialParams.Parity=NOPARITY;
if(!SetCommState(hSerial, &dcbSerialParams)) /*Asignar la configuracion dada por dcbSerialParams al dispositivo dado por la "manija" hSerial */
printf("\nError de SetCommState!");
printf("\nFase SetCommState: OK.");
COMMTIMEOUTS timeouts={0};
timeouts.ReadIntervalTimeout=50;
timeouts.ReadTotalTimeoutConstant=50;
timeouts.ReadTotalTimeoutMultiplier=10;
timeouts.WriteTotalTimeoutConstant=50;
timeouts.WriteTotalTimeoutMultiplier=10;
if(!SetCommTimeouts(hSerial, &timeouts))
printf("\nError de SetCommTimeouts!");
printf("\nFase SetCommTimeouts: OK.");
return hSerial;
int WriteToSerial(char mensaje[]){
sprintf(szBuff, "%s\n", mensaje);
DWORD dwBytesRead = 0;
if(!WriteFile(hSerial, szBuff, strlen(szBuff), &dwBytesRead, NULL)){
printf("\nError de WriteFile!");
return 1;
else {
printf("\nWriteFile: %s", szBuff);
return 0;
main(int argc, char *argv[]){
if(argc==1){
puts("No ha introducido un argumento");
exit(1);
if(port_open(argv[1]) != INVALID_HANDLE_VALUE){
WriteToSerial(argv[2]);
CloseHandle(hSerial);
else {
puts("La comunicacion con el puerto no pudo darse");
exit(1);
This is the code in the Arduino:
int redpin = 7;
int greenpin = 8;
int incomingbyte;
int SensorPin = 0;
float adRead = 0;
float Tmp = 0.0;
void setup(){
pinMode(redpin, OUTPUT);
pinMode(greenpin, OUTPUT);
void loop(){
if(Serial.available() > 0){
incomingbyte = Serial.read();
switch (incomingbyte){
case '0':
Serial.println("Se recibio un 0, LED Rojo ON");
digitalWrite(redpin, HIGH);
case '1':
Serial.println("Se recibio un 1, LED Rojo OFF");
digitalWrite(redpin, LOW);
case '2':
Serial.println("Se recibio un 2, LED Verde ON");
digitalWrite(greenpin, HIGH);
case '3':
Serial.println("Se recibio un 3, LED Verde OFF");
digitalWrite(greenpin, LOW);
case '4':
adRead = analogRead(SensorPin);
Tmp = (adRead/1023) * 500;
Serial.println(Tmp);
PD: Sorry for my english level.
