Arduino Cam Timer
I have been doing Arduino work for some time now, but I have a specific need and I was hoping to get some advice. I am building a prop computer. It will have about 180 incandescent lamps. The lamps are divided into 8 circuits that flash in a sequence. I have already used a 16 channel relay board to make them flash in sequence, but I need them to overlap, in other words, one circuit will stay on after another circuit has just come on. In the original prop, a 3 RPM motor turned cams that switched the circuits on and off.
How do I make some of the relays "overlap" the others? I have read about Millis and I believe that would work. I am slowly figuring out millis by looking at some of the online tutorials but I still don't quite get it.
Again, I am just looking for direction as to where to learn
Thanks
Murphy
JMT2825:
Thanks
Murphy
If this is all your Arduino program will ever do, then millis is not needed. Change the code so you turn off a relay AFTER a you turn on the next relay, and after a short delay.
Paul
There was a similar topic addressed here a few months ago. I wasn’t terriblely impressed with the outcome as I thought the whole thing could have been table driven but it’s worth a read.
Approach to control 9 model fog cannons
Ultimately, it is my belief that it would be fairly easy to replace a cam timer with a table driven Arduino program. It comes down to how many microswitches, how many lobes on the cams and how fast does it rotate...
