Arduino+camera+pc
iam using arduino mega 2560 and linksprite jpeg serial camera. Iam getting continuous pictures in hex form.
I want to save the pictures directly to some folder. i dont want to use SD card. plz guide me.
i shall be very thankfull to u :slight_smile:
here is the code.
byte incomingbyte;
int a=0x0000,  //Read Starting address
    j=0,
    k=0,
    count=0;
uint8_t MH,ML;
boolean EndFlag=0;
  Serial.begin(19200);
  Serial1.begin(38400);
  SendResetCmd();
  delay(3000);
  SendTakePhotoCmd();
  Serial.println("Start pic");
  delay(100);
  while(Serial1.available()>0) {
    incomingbyte=Serial1.read();
  byte b[32];
  while(!EndFlag) {
    j=0;
    k=0;
    count=0;
    SendReadDataCmd();
    delay(75); //try going up
      k++;
      if((k>5)&&(j<32)&&(!EndFlag)) {
        b[j]=incomingbyte;
        if((b[j-1]==0xFF)&&(b[j]==0xD9))
        EndFlag=1;
        j++;
        count++;
    for(j=0;j<count;j++) {
      if(b[j]<0x10)
        Serial.print("0");
      Serial.print(b[j], HEX);
  delay(3000);
  EndFlag = 0; // reset so that another picture can be taken
  Serial.println("End of pic");
//Send Reset command
void SendResetCmd() {
  Serial1.write((byte)0x56);
  Serial1.write((byte)0x00);
  Serial1.write((byte)0x26);
//Send take picture command
void SendTakePhotoCmd() {
  Serial1.write((byte)0x36);
  Serial1.write((byte)0x01);
  a = 0x0000; //reset so that another picture can taken
void FrameSize() {
  Serial1.write((byte)0x34);
//Read data
void SendReadDataCmd() {
  MH=a/0x100;
  ML=a%0x100;
  Serial1.write((byte)0x32);
  Serial1.write((byte)0x0c);
  Serial1.write((byte)0x0a);
  Serial1.write((byte)MH);
  Serial1.write((byte)ML);
  Serial1.write((byte)0x20);
  a+=0x20;
void StopTakePhotoCmd() {
  Serial1.write((byte)0x03);
To some folder where? If you are talking about a folder on the PC, then the application that reads the serial data, on the PC, needs to do that. That is NOT an Arduino issue.
yup on the pc. I found Processing but it seems to be quite complex.
any other easy way?
i have read almost all posts related to this on this forum but no suitable answer. iam trying it by myself just need little guidance :slight_smile:
isshh_sidd:
any other easy way?
In my view Processing is the easiest option.
can you send me the code plz? I've been looking for an hour and I haven't found a way to do it.
isshh_sidd:
No!!!
This is not a code writing service. This is a help forum.
